I am in the final stages of parts gathering for a forged engine build. I have the following:
JDM 302 stroker short block
Ported big valve heads
Comp 127550 cams
Livernois lockouts
TFS adjustable crank gears
I intend to lock the phasers and use the TFS gears and retard the cams 6 or 8 degrees. Do I need to degree the cams? I realize that to extract the most power I probably should but what would happen if I did not degree the cams?
Thanks,
Wayne
Comp 127550 cams
Livernois lockouts
Thanks,
Wayne
