Holcomb Motorsports Civil Wars April 8th-10th
KIMMER
Admin
Holcomb Motorsports hopes all of you will come out and join them for their annual Spring Civil Wars Shootout. They are going to put on a great show for the racers and fans. If you have any questions you can call 800-475-7223 and ask for Kenny or Blake.
We will have a test session on Friday from 9 am to 6 pm 100.00 per car. 20 car minimum. Please call the shop to get your name added to the list
Outlaw 10.5
5000.00 to win
150.00 Car Entry
Rules:
400 Pro Tree Heads Up Racing
2. Engine: (SINGLE POWER ADDER ONLY)
A. Naturally Aspirated
Small Block No minimum weight
Big Block No minimum weight
B. Nitrous Oxide:
Small Block 2300 lbs
Big Block 4.840 & 4.900 Bore Center 2600 lbs (tube cars add 50 lbs)
Big Block 5.00 Bore Center 2700 lbs (tube cars add 100 lbs)
Big Block 5.20 & 5.30 Bore Center 2800 lbs (tube cars add 100 lbs)
C. Turbo Charged and Super Charged (all forced induction tube cars add 100 lbs)
Single SB 2600 lbs Big Block 2700
Twin Turbo up to 94mm SB 2800lbs BB 3000 lbs
Twin Turbo larger then 94mm SB 2900 lbs BB 3100 lbs
Centrifugal Superchargers SB 2600 lbs, BB 2800 lbs
Twin Centrifugal Superchargers SB 2800 lbs, BB 3000 lbs
Roots Supercharger SB 2600 lbs, BB 2800 lbs
Max bore spacing on all forced induction at above weights is 5"
Any forced induction at 5.300 bore spacing add 100 lbs
Max cubic inch on all forced induction entries is 700 cid
Max turbo size 108mm on 5" bore spacing.
Max turbo size 94mm on 5.300 bore spacing.
*Screw superchargers:
"D" rotor 3000 lbs. Max O.D.125%
"C" rotor 3100 lbs. Max O.D. 125%
4 & 6 cylinder alcohol & intercooler permitted No minimum weight
3. Back Half Type Cars Only, Tube cars allowed must add weight, All cars mufflers Recommended
4. Front Frame to be original O.E.M. type. (stock like front frame rails mandatory) Direct bolt in aftermarket Parts permitted. Firewall must be in the stock location. Engine must remain in front of firewall. Firewall can not be modified for engine placement. Tube cars will be allowed must have stock appearing body steel top & quarters (no pro mod body’s.)
[FONT=&quot] [/FONT]
5. Must be Street appearing, must have stock appearing dash and working lights, one piece fiberglass front ends permitted. Hood can be a part of front end. If you use a one piece fiberglass front-end, it must have lights.
6. Alcohol on NON intercooled cars only.
7. NHRA Pro Ladder.
8. Minimum ground clearance of 3" from the front of the nose to 12" behind centerline of the front axle. Wheelbase must be OEM for body style used. Maximum variation from OEM +/- one inch.
9. Towing will be allowed, you must stop at scales, time slips can be picked up at scales.
10. General Rules: deep staging allowed, but track will not wait for a racer to get deep staged. When both Pre-staged are activated, either side stage light will start a 7-second stage count. Failure to activate stage bulb within 7 seconds will result in disqualification/timeout. (Starter's decision will be final). Disqualification will be based on a first or worse situation. Rules on controversial situations will be final at the discretion of the race director.
11. Head & Neck Restraint - Recommended
12. Lower engine containment device (Diaper) - Recommended
13. Maximum front overhang 45" From centerline of front spindle. Tire is limited 33x10.5
14. No car will be allowed to go faster than the chassis is certified for by NHRA.
15. Supercharger restraint system meeting SFI 14.1 mandatory on roots-type supercharger. Screw-type supercharger must meet SFI Spec 34.1 .
For screw-type superchargers, manifold burst panel meeting SFI Spec 23.1 Supercharger drive must be belt, NHRA-accepted chain driver or NHRA-accepted gear drive. Supercharger restraint straps must be covered with a fire-resistant material. See General Regulations 1.10
If one combination appears to have an advantage rules may be changed at track’s discretion in order to keep a level playing field for all competitors.
[FONT=&quot] TCI Transmissions True Ten Five/Outlaw Radial[/FONT]
[FONT=&quot]<a href="http://s206.photobucket.com/albums/bb234/saltnbattery1642/?action=view&amp;current=tci.gif" target="_blank"><img src="http://i206.photobucket.com/albums/bb234/saltnbattery1642/tci.gif" border="0" alt="Photobucket"></a>
[/FONT]
[FONT=&quot]3000.00 to win plus 1000.00 Holcomb Motorsports Contingency. Total Winner is 4000.00[/FONT]
[FONT=&quot]100.00 Car Entry[/FONT]
[FONT=&quot]Rules:[/FONT]
TRUE 29.5 x 10.5 SLICK OR 315 DRAG RADIAL ONLY.
NO FULL TUBE CHASSIS CARS/ BACK HALF OK
ANY ENGINE COMBO ALLOWED.
ANY SUSPENSION ALLOWED
NO WHEELIE BARS
METHANOL ALLOWED
WEIGHTS:
SMALL BLOCK NOS 2600
BB NOS 2800
BB NOS TALL DECK BLOCKS 5" & UP 2900
SMALL BLOCK TURBO AND BLOWERS 2900
BIG BLOCK SINGLE TURBOS AND BLOWERS 3000
BIG BLOCK TWIN TURBOS & ROOTS STYLE BLOWER 3100
X275
4000.00 to win plus 1000.00 Holcomb Motorports Contingency. Total is 5000.00 to win
NRC Motorsports Low ET 250.00
<a href="http://s206.photobucket.com/albums/bb234/saltnbattery1642/?action=view&amp;current=nrcnewsticker.jpg" target="_blank"><img src="http://i206.photobucket.com/albums/bb234/saltnbattery1642/nrcnewsticker.jpg" border="0" alt="Photobucket"></a>
Car entry is 125.00
Go to www.x275.net for 2011 rules
King of the Streets Street Race
2000 to win plus 1000.00 Holcomb Motorsports Contingency
www.king-of-the-streets.org for 2011 rules
Real Street
500.00 to win plus 500.00 Holcomb Motorsports Contingency
Car Entry 50.00 bucks
based on 8 car Minimum
Ultimate Converter Concepts 6.00 Index
1000.00 to win
Car Entry 40.00 bucks
NO BUYBACKS!!!
7.0 Index
1000.00 to Win
NO BUYBACKS!!!
Sunday Combo Index Race 5.30-6.0-7.0 500 to win. Buybacks 1st or 2nd Round. 20.00 bucks. Free Car Entry for Saturday Index Racers
New Entries 25.00
Pro Tree Doorslammers
Saturday 1200 to win Car Entry 35.00
Sunday 1000.00 to win Car entry 30.00
Two day tech Card 60.00. Buybacks 1st or 2nd Round 25.00
Footbrake
Saturday 1000.00 to win Car Entry 30.00
Sunday 1000.00 to win Car Entry 30.00
Two day Tech Card 50.00 Buybacks 1st or 2nd Round 20.00
Open Comp
Saturday 1000 to win. Car Entry 35.00
Sunday 750.00 to win. Car Entry 25.00
Car Club Shootout 25.00 bucks entry
Holcomb Motorsports Presents:
The Club vs. Club Drag Racing Challenge
Come check out 3 local Mustang clubs battle for street/strip bragging rights during Holcomb’s Spring Civil Wars!!! Wide Open Throttle Mustang Club vs. Sandhill Mustang Club vs. Southeastern Foxbodies in a head to head club shootout!! Each club will have 6 cars on the track with all cars will making 3 consecutive ¼ mile passes. Each cars best ET pass will be added to the clubs total ET time. The club with the fastest ET wins!!! So come out and watch these three clubs battle it out on April 9th during the true street event at Civil Wars!!!
All winners in each race class Running Mickey Thompson Tires and Decals will recieve a New Set of Mickey Thompson Tires
<a href="http://s206.photobucket.com/albums/bb234/saltnbattery1642/?action=view&amp;current=MickeyThompson12.jpg" target="_blank"><img src="http://i206.photobucket.com/albums/bb234/saltnbattery1642/MickeyThompson12.jpg" border="0" alt="Photobucket"></a>
Also, please support our Contingency Sponsors as well
Harland Sharp www.harlandsharp.com
Performance Automatic www.performanceautomatic.com
MSD igntion www.msdignition.com
We would like to thank the sponsors that have stepped up to support our racers. Please support these companies that support you guys. Please refer to this thread for more details.
Thanks
Blake Holcomb
Holcomb Motorsports
P.S
If you or your company would like to be a sponsor you can contact me at the number at the top of the page or pm me here.
__________________
Blake Holcomb
www.holcombmotorsports.com
www.myspace.com/holcombmotorsports
We would like to thank our 2010 Civil Wars Sponsors. Please support those that support the racers
Patriot Performance/TRZ Motorsports/Holeshot Wheels/Kooks Custom Headers/Performance Automatic/TCI/Edelbrock/Mickey Thompson/UPR Products
holcombford
We will also be running our Carolina True Street Event on Saturday along with the Club Shootout. We will have an overall winner and then a 10, 11, 12, and 13 second winners. Rules are must have d.o.t. legal tires, tags, registration, etc.
