Agree.
I went from 3.31 to 3.73 with my auto tranny and noticed a helluva difference.
BTW 4.10s in a manual transmission setup gives the same final drive ratio as 3.73s do in an automatic. Final drive ratio = high gear ratio x back end ratio.
Do not get the 3.90's. They are from Motive and they whine like hell based on everything I have read about them. Be sure to get FRPP gears from Ford as well.
All said: 4.10s for you are perfect.
Search gears as well for numerous discussions on this and the math.
Hope this helps.
Mike
This actually brings up a question:
When you go from 3.31's to 3.73's (in my case, and of course with an auto trans), do you have to re tune the trans shift points/line pressures AND the speedo , or JUST the speedo? My local shop only mentioned changing the speedo setting, not any trans re tuning......now I'm wondering if things are set up right? Reason why I'm asking is because if its not shifting at the right times, maybe thats why I don't feel a big difference in the 331 to 373
