why?Its this thread and abdulla's thread that makes me want to sell my cams
lol yeah, the install itself isn't that bad its just a involved process that can be very time consuming.
I still haven't got my oil system primed, front cover is still off. I haven't had the motivation to get it finished
FYI...when I replaced my valve springs, retainers, seals, chains, tensioners, lash adjusters....etc...etc I didn't prime the engine. All I did was make sure everything had a good coating of assembly lube, pulled the fuse for the fuel pump and cranked the engine a few times at 5 second intervals. I haven't had an issue at all and I did that last winter. Unless you're doing a full re-assembly of an engine I don't see the need to really prime it.
The priming is to build pressure in the hydraulic tensioners, so when the engine cranks, the timing chains wont jump teeth.
Big lopey cams suck balls for us that wants perfect driveablity
Note to self: do not install cams.
.......................mmmmmmmmmmkay.........
Ya I went back with metal ones. I was talking about the plastic ones just compressing and decompressingThat's why I rotated the engine both ways before I reinstalled the front cover. I don't know if you used metal tensioners or stuck with the plastic ones, but the metal ones are ratcheting and as I rotated the engine both ways they tightened themselves and the slack was gone.
lol yupFunny....after all the shit that has been spoken about using the hose as the wedge and not one issue with it slipping....huh.
Well. ITS FIXED. I have no clue how the car is going to drive but as far as the rev up and idle recovery stall goes. Its fixed. Vaccum is at 18in vg @ 865rpm OHHH.
