Pumpkinfish
Johnny Quarter Mile
I have had a vibration in the rear and my shop keeps insisting he has my pinion angle at -2.5 degrees. So I decided to check myself. Here is what I found when I put the car on four ramps and used a non-digital angle finder and a metal carpenters square so I can read on the protractor in the same orientation.
trans flange: 2.5 trans pointing down
pinion flange: 2.5 pinion pointing up
To me (and what I have read in the pinion angle sticky), this would be a pinion angle of 0 and it still needs to be adjusted at least 2 degrees down on the pinion, correct? I can see where this shop thinks the pinion is -2.5, but and maybe he is right. That is why I am making this post.
Also, what pinion angle should I start with for a car that makes between 480-490 at the wheels with around 450 torque? I haven't had an updated dyno since the Supershaker went on, but I am guessing I am at similar power levels and I have an all poly suspension.
I am using a BMR uca, so how many turns equals a degree of pinion movement? I downloaded their directions and they don't mention anything.
