Ssiptang
Currently has K springs + stock shocks and I'm upgrading to sportline + koni shocks.
1. Will I need spring compressor? I remember using it when getting the stock springs out but I don't remember using it when installing K springs onto stock struts.
2. On sportline springs, why is isolator/rubber hose glued in the middle? All 4 are like that... I can't even move them because they are glued so hard. Isn't it supposed to be located at the bottom so it insulates against the strut?
3. I'm trying to pre assemble the strurt + springs so I can just swap it. I'm kinda confused on boot/bump stop position on the strut. Do I position it all the way at the top against strut mount or at the bottom against the strut? Or just right in the middle? Does it even matter because I can move it up and down?
4. Any tip on replacing rear shocks by myself? I won't have any help to hold the shocks while fastening the top bolt.
