***Whipple 2.9L Install Write-Up***
S197 GT
PINK Casting Director
Nor Cal
Disclaimer:
Please consult with your tuner for their recommended components based on your application and goals.
It's pretty common knowledge, but for the those who don't know, this kit requires that you grind down a few ribs and bosses on the timing cover in order for the tensioner bracket to mount flush. Please refer to this thread... http://s197forum.com/forum/showthread.php?t=66130
By reading this sentence, you are agreeing to not hold the original poster responsible for any damages you may or may not cause to yourself or others during the install of this supercharger.
Application:
Street Driven 2011 5.0 Mustang w/ MT-82, equipped with Brembo brake package and 3.73s.
Goals:
10 second time slip, 600rwhp, street mannered car that will be comfortable for a 4 year old to go cruise in.
Components:
Whipple 2.9L Crusher Supercharger
3.75" (10 psi) pulleys
JLT Carbon Fiber 127mm Cold Air Intake
Ford Racing 65mm Throttle Body
Ford Racing 47 lbs Injectors
Ford Racing One Step Cooler Spark Plugs (Gapped at .030")
Jon Lund Tune
Install:
Raise the front end of the car.
Go back to the trunk and unplug the Fuel Pump Control Module connector.
Turn on the car to let it idle until it dies. Then crank the engine for a few seconds to release the fuel injector supply manifold pressure.
Disconnect the battery.
Remove the radiator cover.
Remove the front bumper.
Remove the impact absorber and the radiator side shields.
Then loosen the petcock on the radiator to drain the fluid. Taking off the cap first.
S197 GT
Nor Cal
Remove the JLT Carbon Fiber (shameless plug) intake.
Remove the throttle body electrical connector, purge valve and complete tube connecting below the brake booster (you wanna lift up on this clip), and both PCV lines.
Disconnect the supply line to the fuel rail, and both heater hoses. Use the windshield wipers to hold the heater hoses out of the way.
Remove the support brackets for the heater hoses and then remove the steel section of the brake booster vacuum line from the joint near the rear of the intake manifold.
Remove the 3/8" coolant hose from the tank to the engine.
S197 GT
Nor Cal
Remove the (2) harness retainers on the back of my Boss Manifold. The stock intake manifold uses (4).
Remove both fuel rail insulators and disconnect all (8) fuel injector connectors.
Remove the (4) bolts that run through the fuel rails, and the (6) bolts through the intake manifold (these do not come all the way out).
The intake manifold is ready to be removed.
Lift the intake manifold off of the engine and place it to the side with injectors and fuel rail intact.
Clean the exposed surfaces of the intake ports and use painters tape to keep debris out.
Notice the knock sensors in the valley. These will be rotated later in the install.
Remove the coolant tank and then use a 16mm socket to rotate the Front End Accessory Drive Tensioner counter-clockwise in order to release enough tension to remove the belt.
Remove the (4) bolts securing the water pump pulley to the engine.
Cut the AC belt and remove the upper radiator hose.
Remove the (2) bolts securing the electric fan and shroud and then unclipp the harness from the fan.
Remove the electric fan and shroud.
S197 GT
Nor Cal
Unclip the electrical harness clips along the top of the passenger side of the front timing cover to make room for the timing cover grinding.
Make some rough markings for where you'll be cutting and grinding.
S197 GT
Nor Cal
Use a bunch of old sheets to cover the engine. (Thrift store had these for $.85 each)
Use a Dremel to take care of the grinding.
This is a very slow process, but it is easy work. I think a Dremel will ultimately be the cleanest way to take care of the timing cover grinding.
Get all of the complete bosses grinded down, along with all of the ribs. The ribs are very easy to do. All you'll have left is the half cut boss to finish.
We went through about 30 cutting wheels, so plan accordingly if you are going to do this yourself.
Here's how the grinding looks before cleaning the grinds up.
S197 GT
Nor Cal
More grinding...
You'll want to remove (2) water pump bolts to get more room.
Go back and smooth out the bosses.
S197 GT
Nor Cal
Finally cut through the last boss.
Clean up the cuts a bit.
S197 GT
Nor Cal
You're finally done with the timing cover grinding!!!
It isn't that bad at all if you just use the following:
Dremel 4000
Dremel Reinforced Cut-Off Wheels 426
Straight Edge with mm readout
Sharpie Markers
I realized that my best way of doing it is first measuring out the 20mm mark on the semi-cut boss. Put a rough mark on the remaining bosses and ribs. There are no measurements to use, so you just have to use your judgement based on the drawings.
The (2) left-most bosses are easy to get to and really don't require any special notes to follow. The semi-cut boss will require you to remove (2) bolts on the water pump and also the cross section where the upper radiator hose meets the engine. I cut several "slices" into the boss in order to chip away at it leaving room for my Dremel. Once I had a decent amount of material removed, I ended up using the cut-off wheel in a grinding fashion. I turned it 45* and used a side to side motion to bring the surface down even and flush. It works quickly too! Much faster than cutting away at it.
You can accomplish the task of grinding the front cover with just a Dremel!
S197 GT
Nor Cal
Clean everything up well and got ready for the next step which is wiring.
The kit comes with some very nice extension harnesses so that there is very little splicing.
First up is the throttle position sensor. TPS.
Unwrap the electrical tape from the TPS and rotate the harness so that the wires are all straight.
Open up the loom to give you room to work.
Disconnect the "connector" on the TPS harness. This is the red piece that is inside the harness. You do this by gently prying on it with a thin pick.
Once you remove the red connector, you can pry of the back of the harness with the same pick to release the back portion of the harness.
This will have effectively opened up the harness and enabled you to cleanly remove the wires from the harness.
You take the small pick and insert it into the slot above each wire retainer. Gently lift with the pick and the wires will pull right out.
Now that you've exposed all of the wires, you need to grab the TPS harness extension which is included in the kit. Find the TPS connector on the new extension.
Depress the locking tab and separate the male and female ends of the harness.
Replace the old TPS harness connector with the new one from the extension.
Follow the same steps, remove the red connector from the inside of the new harness.
Pry off the back of the new harness. Slide the new back piece onto the exposed TPS wires being sure to note the proper wire configuration. Slide each wire into the back of the harness and you will feel it lock into place.
Slide the back of the harness up to the harness itself and snap it all together. You've just finished swapping the harness connectors on the TPS.
Tape up the loom and exposed wires and the feed the extended harness along the passenger side coil cover and along the back of the valley towards the rear of the driver's side head and use zip ties to secure the harness.
Next up is the purge valve.
This is a similar process, you remove the red connector inside of the Purge Valve harness. Slide the pick into the slots above the wire retainers and pull the (2) wires out. Be sure to note their orientation.
Take the new extension harness for the purge valve that is included with the Whipple kit. This is where it's slightly different. There is nothing to take apart on this harness.
Depress the locking tab to disconnect the harnesses. Take the female section of the harness and you'll notice (2) holes. Slide the exposed wires from the factory Purge Valve harness into this new harness. They will lock right into place.
Now you can connect the new extension to the existing harness and route them along the TPS extension towards the rear of the driver's side head. Be sure to zip tie them as well.
S197 GT
Nor Cal
Next up is the Intercooler Pump wiring.
There is a stud next to the underhood fusebox. Remove the nut and harness from the stud.
Install the relay from the Intercooler Pump Wiring Harness onto the exposed stud. You want to install the fuse previously removed onto the same stud.
I had to drill the hole a bit on the relay to get it to fit on the stud.
There is a red wire attached to the Intercooler Pump Wiring Harness. You'll need to route the red wire to the positive post at the back of the fuse box.
Take the other bundle of wires and route them forward around the front of the fusebox and along the factory lamp harness.
Remove the bolt securing the factory grounds behind the passenger side headlight and secure the factory grounds along with the grounding eyelet from the Intercooler Pump Wiring Harness.
Route the single wire with (2) connectors along the factory engine harness to the rear of the passenger side head.
Connect these connectors inline with the passenger side radio capacitor.
These are hard to see and even harder to get too. Just keep feeling around for the 2 connectors, and you'll find them low behind the passenger side head.
Unplug the (3) PCM connectors to get to the bottom most 70 pin connector.
Remove the front connector.
Remove the wire support on the back of the connector.
Take the supplied Air Charge Temp sensor loom which has the ACT sensor on one end and (2) wires on the other end. 1 wire has a pin crimped on it, while the other has a blunt end.
Pull pin C-56 from the PCM harness.
The blunt ended wire from the ACT sensor loom needs to be spliced with the wire from pin C-56.
I happened to solder mine and used heat shrink.
The wire from the ACT sensor loom with the pin will slide into the empty slot of C-36.
S197 GT
Nor Cal
Extend the Mass Air Flow Wiring. Do the exact same thing as for the TPS and for the Purge Valve.
The kit comes with a MAF extender harness, and you just swap out the OEM harness for the one provided in the kit.
The only thing to note is that the new connector has (6) pins, but the MAF only uses (4) wires. For this, you only use pins 2-5 and leave both 1 and 6 empty.
Make sure the wires are all locked in the new harness and that the colors match on both side of the connection.
Once this is done, neatly tuck the MAF wires back into the wire loom and use electrical tape to seal the loom and complete the extension of the MAF.
Now things are in full swing!
Next up is reorienting the knock sensors. They are located in the middle of the valley between the heads.
Each knock sensor has a 90* plastic wiring retainer that will need to be discarded. Unclip the retainer and undo the electrical tape to remove them.
Loosen each bolt slightly and rotate each knock sensor towards their respective side. The driver's side knock sensor should rotate closer to the driver's side head, and vice versa.
Torque the bolts back down to 25Nm.
Gap the new Ford Racing 1-Step Cooled plugs down to .030" and then swap the plugs.
Pull out the coil covers, release the harnesses on each COP, remove the bolt securing each COP, pull out the COP to expose the plugs.
I was at 10,000 miles, so my plugs came out with no problem.
The order of the plugs in the pic above reads 5-8 on the left side going top to bottom, and 1-4 on the right side.
Here is my #8 plug.
Install all of the plugs, the COPs, and the coil covers.
Next up was the Intercooler Low Temperature Radiator (Heat Exchanger).
Install a rubber grommet into each of the (4) mounting tabs located at each corner.
Run a sleeve through each grommet, and then run a bolt through the sleeve and grommet into each corner's mounting bracket.
There is a little NVH insulator pad that is adhered to the front if the heat exchanger. Just measure 170mm from the top and 140mm from the right and adhere the NVH insulating pad to the heat exchanger.
Next take the Fuel Charging Assembly (lower manifold) and attach a rubber hose from the PCV Purge Hose to the barb on the bottom of the Fuel Charging Assembly.
Next up is relocating the Purge Valve. The instruction manual I received is for the 2.3L kit which is slightly different.
In this case, the 2.3L utilizes a throttle body spacer as a part of it's inlet system and the Purge Valve is relocated to this throttle body spacer.
In my case, with the 2.9L, there is no throttle body spacer. The Crusher inlet runs from the back of the blower all the way around to the throttle body in one clean piece.
Refer to this thread for details regarding the Purge Valve relocation: http://s197forum.com/forum/showthread.php?t=67804
S197 GT
Nor Cal
Mark and drill a 5/16" hole in the fan shroud to mount the Intercooler reservoir.
Clip on a J-clip in the hole and mount the fan shroud.
Mount the Intercooler reservoir using hardware supplied in the kit.
Then remove the (4) bolts/nuts on each corner of the radiator. The radiator will stay in place.
Mount up the heat exchanger using the same (4) mounting points on the radiator.
Use (2) bolts supplied with the kit in the top corners, and reuse the factory nuts on the bottom.
Not much room between the heat exchanger and the radiator.
Next route the intercooler pump hose from bottom of the intercooler reservoir and along the side frame and out the driver's side radiator shield/air inlet.
This picture has the INCORRECT orientation of the hose coming from the reservoir.
It should go underneath the radiator hose and routed like this.
S197 GT
Nor Cal
Then mount both radiator shields.
Remove the top inner (2) bolts from the bumper beam. Replace them with longer replacements from the supplied hardware.
Install the intercooler pump bracket along the inside of the bumper beam by utilizing the bolts from the previous step and the studs just below. Use the (4) supplied nuts to secure the bracket to the bumper beam.
Install another NVH cushion on the back of the bumper beam measuring out 220mm from the driver's side bumper support bracket and 60mm in from the front of the bumper beam.
The intercooler pump mounts to the bracket with (2) supplied bolts. The pump sits perfectly between the NVH cushion installed in the last step and the NVH cushion installed on the heat exchanger earlier in the install process.
The hose from the intercooler reservoir goes to the side of the pump when installed. The other jose goes from the bottom of the pump up to the driver's side of the heat exchanger.
To finish it off run the wiring from the intercooler pump under the main harness, along the back of the passenger side headlight and down through the passenger side radiator shield. Run it down to and along the intercooler pump bracket and plug it into the pump.
The instructions said to use the clips from the harness to mount it to the bracket, but there were none. So I used zipties in the holes of the bracket to secure the harness.
Mount the bumper support foam back to the bumper beam using the factory Christmas trees.
Next up is MOUNTING THE BLOWER!!!!!
S197 GT
Nor Cal
You want to make sure you use some RTV on each of the set screws on the bottom of the blower. Also run a bead along the manifold.
Set the blower down carefully and torque the bolts down in a criss cross fashion.
Mount the (2) brackets used for the tensioner and idler pulleys on the front of the timing cover.
Follow the routing instructions, route the belt around the blower, the idlers, the tensioner, the crank pulley and the AC. Route the other belt around the crank pulley, the power steering pulley, the water pump, the idlers, and tensioner.
This is also a great time to flush out the OEM orange coolant and switch over to something else if you'd prefer. I went with the green Prestone.
Mount the throttle body using the supplied hardware.
Mount your intake to the throttle body.
Triple check all connectors, and reinstall the radiator cover.
The install is now complete.
Load up your tune and begin datalogging or hit the dyno for a dyno tune.
HOLYWD
S197 Junkie
Ty for re-posting this . Most wouldn't .......
Nick FTw - sick car and damn good write up!
