Used, off my car in great shape with around 5k miles. Clutch and flywheel is setup as a unit, has a lightened steel flywheel, discs look good and the floater and pressure plate surfaces are all flat and smooth with normal heat wear signs. It is rated to 950 ft/lbs of torque, ACT part number T2S-F04. Again its a 6-bolt flywheel and has 26 spline clutch discs. I'm including the slave cylinder shim I used with it on my car with the 6060. $750 shipped.
More info on the clutch.
http://www.advancedclutch.com/t2s-f04
