Smoken1986
Nick,
Man it really depends how deep you want to go. I can get a harness but I just wouldn't recommend it. If you are determined, which, ok, obviously you are, much like I was with the heated seats. This is what I would do:
I agree keep splicing to a minimum.
You don't need a harness.
You have the side impact sensors and the plug they came with, you need the other end to that plug. One for the drivers side, one for the passenger.
You will need a wiring diagram for the plugs that go into the RCM. This will tell you which pin does what. I would try and source the plug(s) that go to the RCM from a wrecked car that had sidebags. At the very least you will have to obtain the pins that go inside the plug, FORD does not sell them. Once you determine which pin inside the plug you need to have, carefully take the pin out of the plug along with its attached wire, usually there is a very small piece of plastic holding the pin in, release this with a jewelers screw driver or something really small and then pull the pin out. (the pin kind of snaps into the plug, releasing it is similar to releasing a nylon zip tie, you have to rais the little finger holding the grooved portion of the strap.) Leave the wire attached to the pin. You will splice this wire with an appropriate length that goes to the plug that inserts into the plug from the side impact sensor.
so basicly you are only splicing the length of wire between the used plugs obtained from the wrecked car, four wires total. The wiring diagram will tell you which wire goes where and because you left some wire attached to your sourced plugs the colors will match the diagram. I think this would be less of a pain than a wiring harness which would then plug into, (my guess) the passenger seat sensor, the driver side seat position sensor, the driver air-bag, the passenger air bag, the side impact sensors and the front impact sensors, I am sure there are more connections.
If you decide you want to go back to having no side air-bags and want my RCM, with all the trouble you have gone through man, hell, just pay for shipping and its yours.
Bryan
I hope all this crap makes sense.
