05-10 Zimmers turbo hotside kit
Used off my car for 3-4k miles, some signs of wear but in great shape. I rate the hotside to around 700rwhp as it sits it will make more if you modify the up pipe to the turbo. Kit is mild steel ceramic coated with heat wrap on up an down pipes. No ground clearance problems all piping goes above the k member, great upgrade for an on3 kit will bolt right up with the on3 turbo and coldside.
Includes heavy duty steel turbo support bracket, all vbands and oil filter relocation kit adaptor needed to clear the piping. New motorcraft f1a oil filter and the 10an lines. Also throwing my custom 4" intake and aem dryflow filter I made to better fit the revised turbo location. The kit is modified for a 44-46mm v-band flange wastegate to vent to atmosphere. Tial 44mm wastegate included now. Asking $2050 shipped.
Update. Making the tial 44mm gate standard with the kit since its already flange for it. It currently has a 12psi spring but can be changed out based on your desired min boost level.
Bump. I can throw in my old intercooler, cold side and bov to make this an almost complete kit minus turbo as someone is interested as well.
Heading home on leave soon so, this is up for grabs again as I can ship it. Great upgrade for the on3 kit, solid 1/4" steel mounting bracket, all piping goes above K-member, and you get the better relocation kit ss lines and an fittings and tial 44mm wastegate already dumped. Piping is all coated and up down pipes wrapped, its ready to go on with all clamps as well. Asking $2k shipped, open to offers.
Bump, headed home for Christmas leave again and will be able to ship this setup. I have $3k into this hotside with all the add-ons, modifications, coating and the Tial 44mm vband gate.
Dropping the price to $1850 shipped through the holidays.
