Tensioner question for 2007 Mustang GT
timfoster405
Maryland
Do you only have one version of a tensioner for a 3V?
Does your tensioner have an upgraded, stiffer spring allowing for a tighter belt?
thanks,
Tim
94tbird
4R70W FTMFW
I can answer this. There are two versions of the tensioner for a 3V. There is the original that is good for any amount of power you can throw at it (PM-1002-76). There is also a newer version good for 500RWHP (PM-1006-76). Both tensioner's have stiffer springs, about 30-40% stiffer than the factory springs. You wont find anything with a stiffer spring out there. With your power, leaving room for improvement I would recommend the original Tim
