Fucking crankshaft possion senor!!!
After doing some reading on the net today I found a couple of threads on F150s that had these same codes. One Ford tech was telling a guy about how these codes are set when the PCM sences an intemitant fault on the cam sensors and that the sensors are only used on start up to tell the PCM and CKP sensor where the cams are.
One thing that didnt make sence to me though is why no CEL for the CKP sensor? Well the sensor was working but it has oil seaping through it! When I pulled the connector there was oil inside. I thought about how the FRPS will seap fuel when they go bad and for $25 it was worth a try.
Thats when I thought to myself well then if there is only an itermitant short then maybe, just maybe, it could be the CKP sensor. Ran down to the local Napa and bought one and sure enough no more CEL.
I have started the car four times now and no code and it was like clock work before, every second start after clearing the code. I am going to let the car sit a while and start it a few more times later.
As for the Optima battery Bruce, this is the first time I have every had trouble with on is on this car. The first one (Redtop) sat over two yrs while the car was down and the second that I just took out was only six months old so IDK there. From the reading I did on Optomas site thismorning the Redtop really doesnt like to sit and not be used. That is where the switch from the red to the yellow can in. They say the Yellowtop is like a combination of the Red and Blue (marine) and it can take the beating of being ran down lower along with being able to sit without issue.
Weather should be better here tomorrow and I will do some driving to test further.
