SherrodMustang
For your bold print question... I asked JimIII from JDM the same question... Heres his response, word for word
"If the timing marks were off and you spun it over by hand there is a good chance you would still have clearance. If the valves hit you would feel it. The difference however with a running motor is the VCT is operating, now if the cams went into full retard or advance its posssible the valves would touch."
Most likly you cant hit the pistons just by turning the motor over by hand, again the 6 oclock crank position makes sure of this.... I only pulled my rockers for a piece of mind knowing there was no way that I hit pistons..... Just me being paranoid![]()
How did you remove the rockers? Tool?
Scared of the release of the cams moving so much to hit the valves without removing the rockers. Then getting them back to put the chains back on with tension. But if there is no chance of the valves coming close this would be the way to do it. I guess if the marks are correct crank and sprocket there is no chance it is timed wrong.
