Transmission swap questions!
PiggityPonyBoy
2010 v6 mustang 5R55S to T5(06 or 07?) transmission swap:
Will the driveshaft for my 10 fit the T5?
And with all the parts and pieces the T5 should be able to bolt right back into place like my pos automatic, right?
Any help would be appreciated. I would much rather have a driveshaft if it didn't fit and do the swap all in one day, rather than being w/o a car for two to three weeks.
Any other minor parts i'm forgetting about?
Ps: also heard my ECU would throw a code cause it would think the tranny was broken or gone... is that true too?
Juice
That's going to be a big job. Don't forget you need to install the 3rd pedal and all the hydraulics.
Yes, the PCM will have a fit. I'm not sure, but you may be able to flash it with a manual calibration.
Where are you located? I have just about everything you need to do the swap except the pedals, shifter boot, and hydraulics. 106K miles. All decent, clutch was toast.
