Threw a code 2195, (02 sensor biased stuck lean bank 1). I've read that you shouldn't solder the wires on the 02 sensor. Should I try re-using the existing 02 sensor but reconnect using a crimp connector and shrink wrap over the entire connection, or re-splice in a new 02 sensor using the crimp connection and heat shrink. I'm going to have to at least lower the rear of the trans to get to the damn plug that sits nearly on top of the trans, and also remove the mid-pipe so the engine can tilt back.
The odd thing about the whole ordeal is that the car has had soldered in extensions for the front 02's for a while now with quite a few miles with no problems and all of the sudden the soldered connections are causing this???
