So I kept getting a stuck rich code on my bank 1 sensor. Just put a new sensor in along with a harness extension. My last two sensors I soldered in extra wire for it to reach the main harness. This time I used some extensions just for ease. Well now I get P2195 stuck lean. It has been the same Shelby tune for the last 5 or so years. The only thing I've done to the car recently was a new front cover and different Meziere. Here is a quick vid of my A/F guage idleing in my garage.
https://www.youtube.com/watch?v=_V4WmBxT840
If you watch the vid (kinda boring) you can see the A?F ratio drop to way rich. A couple blips of the throttle then it returns to normal.
And then it creeps to full lean.
I don't get any slow response or heater circuit codes. With the previous stuck rich code and now the stuck lean code I am leaning toward a wiring issue. I did a semi wire tuck a few years ago but I never touched the O2 wires. I did swing the whole harness around the engine a little bit so the location of the connector for that side is harder to reach.
Anyways, I hate wiring and such, so is there other things I should be checking before diving into rewiring the sensor to the ECU? I haven't datalogged yet as my home computer is being hinky and I don't have a laptop. I could probably set up a log with short and long fuel trims and fuel pressure. What else should I be looking at as far as the logging?
