BMR Suspension New Product - S550 Motor Mount Brackets - MM008
BMR Suspension
2015 and Newer Mustang Motor Mount Brackets
MM008 $169.95
Reduce engine movement and improve throttle response on your 2015 and newer Mustang with Motor Mount Brackets from BMR Suspension. The factory mounts are bulky and don’t leave room for large exhaust options. They also don’t give you the ability adjust engine height. The BMR mount brackets are constructed from 1/4-inch, laser cut steel plate with aircraft-grade 6061-T6 billet aluminum spacers. The BMR Motor Mount Brackets (PN MM008) allow you to lower the engine by as much as a ½-inch, and give you additional room for large-tube headers or turbo kits. The brackets bolt to the factory motor mount bushings, adding all this with no change in NVH. Installation time is 3-4 hours. Available in black hammertone or red powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit
www.bmrsuspension.com, email [email protected], or contact them at BMR
Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
