Do I need new flywheel bolts
Lawlessjay
I am replacing the clutch and flywheel on my 13 GT, do I need to get new flywheel bolts like from ARP or can I reuse the stock ones?
01yellerCobra
San Diego, CA
Usually an easy way to tell is the torque spec. If it includes "turn XX degrees" it's a TTY and should be replaced. If it's just an in-lb or ft-lb spec they can usually be reused.
That being said I'd compare the cost of new bolts to the chance of something failing from an old bolt that's overworked.
Sent from my SAMSUNG-SM-G935A using Tapatalk
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
I'll re-use them 3-4 times before considering replacement. I'm yet to see a flywheel bolt failure.
travelers
Eastern Pa
Here is what Ford Service manual says
  1. NOTE: The flywheel bolts are torque-to-yield design and are not reusable.
    Remove the 8 bolts and the flywheel.
    • Discard the bolts.
    • To install, tighten in the sequence shown in 2 stages.
      • Stage 1: Tighten to 20 Nm (177 lb-in).
      • Stage 2: Tighten an additional 60 degrees.
pass1over
I like it LOW
Trenton, FL
had a tech use the Nm figure and clicked that up on his ft/lb torque wrench when installing some flywheel bolts once on a 350z. Tightened 3 of them before one finally snapped off
rocky61201
SoCal
What he said. After breaking off a water pump bolt flush with the block I will listen to Ford from now on and never re-use a bolt when Ford says not to. The cost of a quality bolt/screw extractor kit with premium left hand drill bits will cost you way more than new bolts.
Either new oem bolts or just go ahead and upgrade them. I upgraded to reusable arp flywheel bolts, they are sold in sets of 8.
While I don't know if there is really a difference for 2011+, I used part number 254-2801 for my 07. Which lists as a 96-04 part most places but is really 96-10 at least.
