S197 Mustang Forum - S197Forum.com
Go Back   S197 Mustang Forum - S197Forum.com > Mustang s197 Tech Forums > 2015+ S550 Mustang 2.3L Ecoboost Tech
Reply
Thread Tools Display Modes
Old 01-22-2016, 06:53 AM   #21
Boaisy
Dark Knight
Boaisy's Avatar
Boaisy is an unknown quantity at this point
Default
Quote:
Originally Posted by Greg Hazlett View Post
100+ psi....?
Yep. You do a Google search, there are a lot of Cummins diesels that people have put that much psi into, used for competition mostly. However, there are people trying it out on different motors, but, as mentioned above, they are having to go through extensive measures to make it work. Obviously, not practical for a regular car.
__________________
2012 Mustang GT - Dark Horse - SOLD
2015 F-150 XLT Sport - Phantom
Quote:
Originally Posted by GallopingFord View Post
...it sounds like it just murdered a bunch of babies.
Boaisy is offline   Reply With Quote
Old 01-25-2016, 12:29 AM   #22
Speedboosted
Found missing cylinders
Speedboosted's Avatar
Speedboosted is an unknown quantity at this point
Default
Quote:
Not "hard" to run that much on a competition prepped diesel by any means. Hell, my Boss' 6.4 runs 53ish pounds and it's not even that crazy. We did a twin turbo build on a 5.9 Cummins a couple months ago and he finally made it over to the dyno. Laid down over 900 whp and 1700 tq.
__________________
2006 3v Swap: Road Course Toy- Lito Tuned
2006 GT: Built motor with Paxton A2W- new DD- Lito Tuned
Speedboosted is offline   Reply With Quote
Old 02-13-2016, 11:01 AM   #23
s8v4o
s8v4o's Avatar
s8v4o is on a distinguished road
Default
No, EFR 7163.
Looks like they might need another upgrade soon. Looking at the specs of that turbo looks like max flow is 60 lbs/min. Using old school math you would multiply that by 10 to get a HP figure.
Quote from Garrett turbos...
"What is my mass flow rate? As a very general rule, turbocharged gasoline engines will generate 9.5-10.5 horsepower (as measured at the flywheel) for each lb/min of airflow. So, an engine with a target peak horsepower of 400 Hp will require 36-44 lb/min of airflow to achieve that target. This is just a rough first approximation to help narrow the turbo selection options."
Was the turbo maxed out? If we use the 10.5 multiplier we actually get pretty close (60 x 10.5 = 630HP or 535WHP). If the turbo is maxed out they could get a bigger one and run a little less boost and make the same power if not more.
This is great though to see such power from the new ecoboost engine!!! Anybody have a complete mod list for this car?
__________________
JLTII / SCT Livewire / SCT PRP / UDP's / ORH / LM1 wideband / ZEX / WOTBOX / SLP line locks / Racestars
s8v4o is offline   Reply With Quote
Old 02-16-2016, 07:41 PM   #24
[email protected]
Official Site Vendor
Jared@Lethal's Avatar
Jared@Lethal is on a distinguished road
Default
Here ya go.
Lethal Performance Turbo Kit 7163EFR turbo from Borg Warner
Lethal Performance Intercooler Upgrade kit
Lethal 3" Offroad downpipe with electronic cutout
Lethal Aux fuel system with additional 465lph pump, Micro squirt controller, CP-E secondary fuel rail and 4 additional 13-14 GT500 fuel injectors
Barton Shifter
DSS carbon fiber driveshaft
DSS 800hp Halfshafts
Viking Performance Crusader Shocks
BMR
BMR 2015 MUSTANG CRADLE BUSHING LOCKOUT KIT
BMR Driveshaft Loop
BMR 2015 MUSTANG DOUBLE ADJUSTABLE REAR TOE RODS (RED)
BMR 2015 MUSTANG BILLET ALUMINUM VERTICAL LINKS
BMR Bushing Kit, Differential Lockout
Racestar Wheels
Lund Racing Custom Tune on a LR nGauge
N2MB Wot Box
Anchor Room Tint Kit
Diode Dynamics Switchbacks and LED Conversion Kit
50psi Map sensor
__________________
LETHAL PERFORMANCE, INC.
www.lethalperformance.com
877-2LETHAL
Whipple Supercharger's Largest US Distributor
MCLEOD, Spec, Ram, Fidanza, Centerforce Always in Stock!
Steeda, BMR, MM, UPR, CHE -Suspension
Jared@Lethal is offline   Reply With Quote
Old 02-16-2016, 09:59 PM   #25
Greg Hazlett
Stepping on the Pink Bus
Greg Hazlett's Avatar
Greg Hazlett will become famous soon enoughGreg Hazlett will become famous soon enough
Default
Thanks Jared!
BW EFR is the only turbo I would use if I were to upgrade
__________________
If common sense were truly common there would not be the need to talk about it.....
Greg Hazlett is offline   Reply With Quote
Old 02-17-2016, 02:05 PM   #26
s8v4o
s8v4o's Avatar
Default
Quote:
Originally Posted by [email protected] View Post
Here ya go.
Barton Shifter
BMR
BMR Driveshaft Loop
Racestar Wheels
N2MB Wot Box
50psi Map sensor
Nice, using a microsquirt as a piggy back I'm assuming. The mega/micro squirt is some pretty cool stuff. I'm thinking you might have been able to use the microsquirt to take on the duty of the WOTBOX. Probably would have been a little more involved though.
__________________
Old 02-18-2016, 01:49 AM   #27
Pentalab
Pentalab is an unknown quantity at this point
Default
Quote:
Originally Posted by tjm73 View Post
Imagine an Ecoboost 5.0.......
Direct inject 5.0 Eco-blaster would be the real ticket...then toss in the flat plane crank et all. Ford, what are you waiting for ?
Pentalab is offline   Reply With Quote
Old 03-26-2016, 08:59 AM   #28
skaarlaj
Probie Former Pink Bus Rider
skaarlaj is an unknown quantity at this point
Default
I can't help but think that would've been a low-mid 10 second pass with a stalled auto, or similar times that the car ran with a "pump-gas-friendly" amount of boost. Then again with direct injection, detonation can't occur if there's no fuel charge to even ignite, so who knows how much timing/boost a person could get away with on one of these!!
__________________
Kona Blue 2011 premium GT with 32,000 miles!
Paxton, 8 ribbed, wastegated, ATI 20% od balancer
6R80, 5C converter, Mid Atlantic tuned
Pypes long-tubes, and off road X into MBRP axle-back mufflers.
skaarlaj is offline   Reply With Quote
Old 05-06-2017, 01:48 PM   #29
Smalls5oh
Smalls5oh is an unknown quantity at this point
Default
Very impressive for a 4 banger.
Smalls5oh is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Ad Management plugin by RedTyger
