On-Car Adjustable Aluminum Panhard and Sway Bar End Links
HC_Tad
IA
Double-Adjustable Aluminum Panhards and Double Adjustable Aluminum Front Sway Bar End Links are on sale now!
The forum member price is $95 shipped for either product via UPS Ground. Or $180 for both! Orders come with a free shirt. Orders come with a free white or silver window decal if you want it as well.
Proudly Built In The USA!
These Stallion series double-adjustable T6 aluminum Front Sway Bar End Links come with MWC rod ends, aluminum bushings, and can even be adjusted while on the car! They are a direct fit and come with mounting hardware. These replace the factory non-adjustable end links. These allow you to tune the front suspension and adjust the preload. These will transmit some noise so they are suggested for competition applications.
This Stallion series double-adjustable T6 aluminum panhard bar comes with MWC rod ends, and aluminum bushings. If you've lowered your car, your rear wheels are no longer centered on your car. Our double adjustable panhard bar will fix that problem for you and can even be adjusted while on the car! They are a direct fit and can use the oem mounting hardware.
These panhards come with rod ends/heim joints unless you would prefer poly on one or both ends. Poly ends are an additional $8 per end.
Please check out our full Stallion line at the web address in my signature.
We also offer a panhard relocation bracket for $50, or $35 when ordered with this panhard!
Free shirt choices...
