Rehagen Racing
Factory built racecar from Ford Racing. These cars originally sold for $124,900. We purchased the car from its owner a few years ago and have not had much use for it. We bought it because it was a nearly virgin car with very little race history. There may be a total of 6 races on the car. It has never suffered any major damage. There was some very minor cosmetic damage, but the car was just recently refreshed and repainted in white (receipts available). Everything on the car is functional, but it has not been raced or driven in over a year. The driveline is in good condition. The car runs and drives excellent, and we would not hesitate to take this car straight to the track after a quick inspection (nut/bolt check). This is as close to a factory original FR500C, that we know of still in existence. This car has had a new engine installed just prior to our purchasing it, but we do not know how much time was on it when we bought it. We got very few records as the previous owner had passed away (the reason the car was sold).
Front brake system is all 100% brand new!
Rehagen Racing can maintain and support this car in any series if the buyer wishes to go racing and needs that level of support. We can also update the car with our proprietary upgrades if this car is to remain in our stable.
Below are the specifications listed for the cars directly from Ford Racing. There have been a few updates to the car, but the listing is fairly accurate. This is as close to a production car as we have seen.
The car has the following upgrades not included with the original car:
Ford Racing carbon fiber brake duct kit
Exedy Racing Clutch
We can assist you in arranging shipment or delivery
RACE SERIES Grand-Am Koni Challenge
ENGINE
· 400 HP (approx) 5.0L "Cammer R50"
CHASSIS
· Uni-Body seam welded integrated safety cage
· Structural: Over 20,000 ft-lbs/degree (torsional)
· Construction: Ford - modified stock steel
WHEELS/ TIRES
· Wheel: Fikse/ Ford Racing - 18 x 10.00
· Tire: Hoosier 275 / 35 - 18
BRAKES
· Brembo 4 Pot/ PFC Race Pads
· Ford - PFC Race Pades
· Master Cylinder: Ford Racing
· ABS: Ford Racing
STEERING
· Steering Rack: Ford Racing Rack and Pinion
· Power Steering: Ford hydraulic
DIMENSIONS
· Wheelbase: 107.1 inches
· Front Track: 62.8 inches
· Rear Track: 63.0 inches
· Minimum Dry Weight: 3160 lbs
FUEL
· Fuel Cell: ATL Custom Dual Dry Break 20 Gal.
· Fuel Pumps: Walbro 255L/H
· Pressure Regulator: Ford
ANCILLARIES
· C&R aluminum radiator with integrated oil cooler
· Ford Racing harness
· Ford Racing exhaust system
· Ford Racing high flow intake system
· SPARCO 4.0 Liter AFFF cable activated extinguisher
FRONT SUSPENSION
· Dynamic Suspensions - inverted struts
· 3 way adjustable - high/flow speed compression, rebound
· Ride heights adjustable coil over
· Adjustable caster/ camber plate
· Urethane bushings
· Adjustable anti-roll bar
REAR SUSPENSION
· Dynamic Suspensions - dampers
· 3 link with panhard bar
· Urethane bushings
DRIVELINE
· T-56 6 speed transmission
· 3.55 Rear 8.8" Track Tech C Locker
· Ford Racing Performance Parts clutch (Upgraded to Exedy)
COCKPIT
· SPARCO racing seat - position adjustable
· SPARCO steering wheel - quick release
· SPARCO 6-point safety harness
· Center mount console switches
· AIM digital dash system - data logging and display
For more information about this car, please contact Rehagen Racing at 734-895-1543 or via email at [email protected].
We have two additional cars available for sale. All 3 may be purchased for a total of $99,995. If you are interested, please contact us to create a new listing.
LOTS OF PICS AVAILABLE
Exedy Racing Clutch
ENGINE
CHASSIS
WHEELS/ TIRES
BRAKES
· ABS: Ford Racing
STEERING
DIMENSIONS
FUEL
ANCILLARIES
FRONT SUSPENSION
· Urethane bushings
REAR SUSPENSION
· Urethane bushings
DRIVELINE
COCKPIT
