5.4 3V Heads,intake,timing cover,etc..
JST4FN
Tyler,Tx
Now that I've swapped everything over to a 4V I no longer need my 3V stuff. These parts are for a 5.4 3V although the heads and cams will work on a 4.6.
Heads - SOLD They are 05 heads with around 30000 miles total(15000 stock/15000 modified). They have stock valves. They were lightly hand ported by me and would probably be equivalant to a stage 1 port job. They have Manley valve springs (12000 miles), and new viton seals (0 miles). They have not been used since they were cleaned up and had new valve seals installed.
Cams -SOLD The cams are Bullet Racing custom grinds (238/245 .050 , .473/.480 lift, 115 LSA) with 3000 miles or less on them. The cam phasers also come with them and have limiters installed.
Intake - $400plus shipping. The intake and water crossover are for a 5.4 3V. My friend made the intake and eventually I bought it from him. You can use a stock TB or GT500 with a spacer and elongated holes. The thermostat cover was changed to allow this. The inside does have oil residue so you will probably want to clean it.
All this stuff is used with different mileage.
Thanks Mike
JST4FN
Tyler,Tx
A few people have asked about the cams so I decided to offer them separately from the heads. They were ground for a turbocharged engine although they should work for other applications.
Thanks Mike
BruceH
BBB Big Bore Boss 322
Thanks Mike
Do you have the cam card? I think that posting it up would help anyone who is looking at them.
Of particular interest would be the intake center line and valve timing events.
JST4FN
Tyler,Tx
Bruce I added it for you.
Thanks Mike
JST4FN
Tyler,Tx
A few more pictures of the head ports and intake.
Thanks Mike
JST4FN
Tyler,Tx
Open to reasonable offers on this stuff. The cams and heads fit 4.6 and 5.4's. The intake and timing cover are 5.4 parts only. If you want to make an offer please send me a pm.
Thanks Mike
JST4FN
Tyler,Tx
Bump... Updated prices. I'd like to find a new home for this stuff.
Thanks Mike
JST4FN
Tyler,Tx
They are the same. Hopefully I didn't confuse people with that. The intake, timing cover and chains are the differences. The cams, heads and cam covers can all be used with a 4.6 or 5.4.
Thanks Mike
