Tire Comparison: M/T’s ET Street Radial Versus ET Street Radial II
tigerhonaker
TN
Guys,
I just saw this last night and I think many of you would also like to See & Read this "Article".
http://www.stangtv.com/tech-stories/wheels-tires/tire-comparison-mts-et-street-radal-versus-et-street-radial-ii/294549
by Andrew Wolf on May 3, 2013
Comments
Mickey Thompson’s ET Street Radial and the newer ET Street Radial II are a couple of the prime
choices of street and strip enthusiasts in search of a drivable, yet well-performing tire for their
powerful daily drivers or weekend warriors. While each option offers exceptional performance
on the road and the strip, these two tires have a design catered to a more specific use and
driving style.
To illustrate the differences, we recently bolted on a set of both of these tires to our
11-second, supercharged 2011 Ford Mustang GT Wild E. Coyote and put them to the test in a
side-by-side comparison to determine how they perform. In our test, we were looking not just
at which performed better on the track, but how they handled out on the highway and in
traffic. The truth is, you can’t go wrong with either tire…it all comes down to what your end
goal is and what you need in a tire. But if you want to know how they stack up, you’ll want to
continue reading.
Left: Our test bed, shown with the 295/55/15 ET Street Radial tires on a set of Weld Racing
RT wheels. Right: the 15-inch ET Street Radial and the 18-inch ET Street Radial II in a
265/40/18.
ET Street Radial
The first tire we tested, the venerable ET Street Radial (295/55/15), is one of the most popular
tires in use on street and strip vehicles like our 600 horsepower Mustang, and for good
reason: it’s a DOT-approved street legal radial design that delivers a great ride on the street
with a soft compound designed more for traction on the track. The Street Radial was also the
tire to beat in Outlaw Drag Radial and 275 Drag Radial racing. Since then, M/T has produced a
more hardcore, and not street recommended, 275 Street Radial Pro that took 275 Radial Racing
to the next level.
The 15-inch ET Street Radial, which requires the added cost of an aftermarket wheel.
“We developed this tire a couple of years ago as a direct replacement for the old Chevelles
and such, and it spilled over into the Mustang market because it’s a true 28 x 10.5, 15-inch tire.
It’s a got a taller sidewall that works very well on the drag strip. There’s just no better way to
sum it up than by saying it’s just an excellent-working tire,” said Mickey Thompson’s Tom
Kundrik.
Chevelle’s and such, and it spilled over into the Mustang market because it’s a
true 28 x 10.5, 15-inch tire. – Tom Kundrik
The ET Street Radial is, however, more of what you’d call a dedicated drag racing setup inside
and out. It’s got a beefier sidewall construction for launching on the strip, and low-void
directional tread that handles well on dry pavement, but isn’t recommended for rain or snow
driving. Mickey Thompson makes clear distinction that this is a drag racing tire for dry use
only, so don’t say you weren’t warned.
One thing we discovered on our Mustang, and which is common on a lot of later-model
vehicles, is that you may have to make provisions in the suspension system (the sway bar
location) to fit the 15-inch wheel, or perhaps go with the 17 to 20-inch Street Radial II entirely
due to fitment issues.
ET Street Radial II
The ET Street Radial II (we’re testing the 265/40/18), unlike the 15-inch Street Radial, is
intended for a more all-around use. It’s no slouch at the track, but that isn’t it’s forte by
design. This second-generation tire is likewise a soft compound, radial tire that’s completely
DOT street legal, but inside, has a polyester ply, steel belted construction like a more typical
OEM street tire for strength and long-term durability on the road. Another focus of this tire —
and its 18-inch size — is to accommodate some of the large aftermarket brakes that are
common on many of today’s souped-up street performers.
The 265/40/18 ET Street Radial II tire. We drove this tire for 5,000 to 7,000 miles in all type
of driving conditions without a hitch.
“The ET Street Radial II is meant to be the best traction tire on the market for high horsepower
Corvettes, Mustangs, and other performance vehicles. You can drive it on the street with a
thousand horsepower and it will hook up. It’s far better than any original street car tire out
there, and you can drive it to the race track and have a superior-performing tire there, too. You
don’t have to switch back and forth between a slick and your radial to drive home,” explained
Kundrik.
The 18-inch tire, as you can imagine, is going to handle better because it has a shorter aspect
ratio for sidewall and thus a stiffer sidewall for less flex. It’s not an autocross tire, but it will
drive and handle well.
The Differences
Both the ET Street Radial and the Street Radial II use the very same compound in their
construction, and in all reality, they aren’t vastly different tires, but there are some tradeoffs
to one over the other. What sets them apart more than anything is their sidewall construction,
which brings about differences in how they perform out of the gate at the track.
You can see the differences in the tread of the two tires in this detailed side-by-side shot.
Mickey Thompson spread out the tread blocks more like that of an OEM street tire on the
18-inch ET Street Radial II to give it better driveability on the street.
Shown here are the ET Street Radial and ET Street Radial II side-by-side.
As we’ve pointed out, the 15-inch ET Street Radial is more of a drag racing-esque tire with a
focus on on-track performance, and that’s where it shines. And much of this is owed to its
larger sidewall depth, allowing it to squat and wrinkle when the power is applied at the starting
line.
Measuring The Differences
ET Street Radial: Section Width 12.0″, Tread width 10.9″, Diameter 27.8″, Measuring Rim 9.5″
ET Street Radial II: Section Width 10.6″, Tread width 9.6″, Diameter 26.5″, Measuring Rim 9.5″
“The 15-inch ET Street Radial is going to be more forgiving at the race track, because it has
more sidewall,” says Kundrik.
“The larger sidewall really lets the 295/55/15 tire wrinkle up. Most people don’t think that a
radial tires wrinkles, but if you watch some of the really high horsepower cars in Outlaw Drag
Radial and such, it will have wrinkles all the way around almost like a slick. But by the
sixty-foot mark, it’s already back to round. Radials stay round and they’re very stable.”
Another area where these two tires differ is in their contact patch and tread pattern. The
15-inch Street Radial is roughly 1-1/3-inches wider (10.9 inches versus 9.6 inches in tread
width) than the Street Radial II, providing extra real estate on the pavement for traction. It’s
tread design, however, doesn’t lend itself as well to road driving, particularly in less-than-clear
weather conditions.
“The first-generation tire has a more aggressive contact patch that isn’t meant to dissipate a
lot of water,” says Kundrik. “It’s meant for straight-line traction and performance. The ET
Street Radial II, on the other hand, is designed more for every-day use at maximum
performance.”
to dissipate a lot of water. The ET Street Radial II, on the other and, is designed
more for every-day use at maximum performance. – Tom Kundrik
The Street Radial II will get the job done on everything from daily drivers-turned-dragstrip
warriors to show cars and weekend cruisers. If you need to drive your car and don’t want to
carry around and swap a set of tires, this tire fits the bill.
“It’s going to be better if you get caught in a little bit of rain or anything, but with it’s shorter
aspect-ratio sidewall, it isn’t going to be as forgiving on the drag strip. We knew the 16, 17,
and 18-inch size tires were going to be used more on weekend street-driven cars, so we
wanted to make it handle better in the rain. But we definitely wanted it to perform and drive
well, so we broke up the tread squares more as well,” said Kundrik.
To sum it up, “if your car is a daily driver or a weekend warrior, the 18-inch tire would be
perfect. If you’re going to the race track all the time, you definitely would want to run the
15-inch tire because it’s going to be better for higher horsepower cars,” added Kundrik.
Our Findings
As we alluded to in our introduction, we tested both the Street Radial and Street Radial II on
the street and on the track. Not surprisingly, we found the two tires to be fairly close on the
dragstrip in terms of their pure sixty-foot and elapsed time potential, but there were some
distinct differences in their overall consistency. After all, one is designed for the track, while
the track is only a component of the other.
Testing the 18-inch ET Street Radial II at the track on the stock 2011 Mustang GT wheels.
Throughout our passes, the 15-inch Street Radial was the more consistent tire. This is
particularly of emphasis if you have a stick-shift car like our Mustang, because radials aren’t
generally a dump-the-clutch type of tire. Discovering and maintaining just the right amount of
slip and hitting that “sweet spot” on each pass is key to making the 18-inch tire consistent, so
the 15-inch gave us a little more margin for error. As it should, the 15-inch tire had noticeably
more squat on the launch.
Another point to keep in mind is that the two tires are 1.3-inch difference in diameter, which
will effect your gear ratio and change how the car performs down low and going down the
race track. It will also, naturally, change your shift points on a clutch car.
We made four runs in total at the nearby Irwindale Dragstrip and again at Bakerfield,
making one run in each lane on both tire.
We made four runs in total on two different dragstrips, two on each tire and alternated
between the left and right lane. The best performance, which we expected, came from
Bakersfield better-prepped quarter mile track. Our best run came on the 15-inch Street Radial
(and was also our first run of the day), as we netted a quarter mile elapsed time of 11.37 at
120.54 mph, with a 1.79 sixty-foot time, which was also the best of the four runs.
On our second pass, over in the right lane, we slowed to an 11.51 and lost a tenth in the short
time. We then bolted on the 18-inch ET Street Radial II’s and made a pass in the left lane,
carding our slowest run of the four, an 11.546 at 121.66 mph with a respectable 1.85 sixty. Later
that afternoon, we made one final run in the right lane. A 1.79 short time, just a tick off our
best pass on the 15-inch tires, translated into our second-best quarter-mile numbers of the
day, as the scoreboards lit up with an 11.48 at 118.33 mph.
On the left are the two passes recorded with the 18-inch ET Street Radial II tires, while the
two passes on the 15-inch Street Radial (including our best run of 11.37) are shown on the
right.
Naturally, comparing how the two tires drive on the street isn’t calculable like a time slip is, but
rather, it’s all a seat-of-your-pants opinion. We were able to log plenty of miles on both tires,
and found the stiffer sidewall of the 18-inch tire to perform similar to an OEM street tire, with
the ability to not only handle well in the rain, but in a pinch in an accident-avoidance
situation. The tire reacted well to the drivers motions, whereas the sidewall flex of the 15-inch
tire was noticeably slower to react.
In Summary
You’ve read about the two tires and you’ve seen our results. Now, which is the right pick?
Well, there really isn’t a right pick. It’s all up to you. The main thing to keep in mind is the
cost-to-benefit ratio and how it plays into your needs. On some newer vehicles like S197
Mustangs, you can’t install a 15-inch wheel because of the location of the sway bar. This
means there are steps (particularly, sway bar relocation) that will cost you a little money and
some time in order to bolt up the 15-inch tire if that’s what you choose to go with. Of course,
you also have to buy 15-inch wheels. If you’ve got the money, the 15-inch tire is going to be
more consistent, no question.
To get the smaller 15-inch wheel to fit, we had to relocate the sway bar on our late model
Mustang. The kit we purchased from Steeda is less than $50 and takes around an hour or
two to install. This is a step that you may have to undertake on your vehicle, depending on
the sway bar location.
If, on the other hand, you’ve got a daily driver or just want to the cruise the street and hit
occasional test and tune nights at the track, the 18-inch ET Street Radial II can be fitted to
your stock wheels, and you can drive it every day. We drove on the 18-inch tire on our stock
Mustang wheels for an estimated 5,000 to 7,000 miles at 75-80 mph — even in the rain —
without any issues whatsoever.
At the end of the day, you can’t go wrong. Pick a tire and have fun with it.
Terry
FIVE-OH
Good review. But the "You can drive it on the street with a
" part about the Street Radial II made me chuckle...
blownGTvert
Zeeland, MI
I wish this article would have included the newer version ET Pros. The Pros will have similiar characteristics as the 15" ET Streets. But the Pros widen the gap even further in terms of traction versus ET Street II tire. Not to mention the 15" ETs cost 50% less than most ET II tires.
tigerhonaker
TN
Thanks for posting pretty good read!
Yes, I thought it was worth sharing with the S-197 Crew :beerdrink:
Well, I think we all know that probably was not to be taken literally.
I did take a 2nd-look at that comment though.
I wish this article would have included the newer version ET Pros. The Pros will have similar characteristics as the 15" ET Streets. But the Pros widen the gap even further in terms of traction versus ET Street II tire. Not to mention the 15" ETs cost 50% less than most ET II tires.
I think the Pro being strictly a Drag-Race tire and it really not meant to be actually driven on the street
is why the test was done with the "Original" ET Street Radial and the "Newer" ET street radial II tires.
The Newer series PRO are the Shit for traction !!!
But you are not ever going to drive with those on the street they are really ONLY for the Drag-Strip.
I know guys running them.
Terry
BTW,
I just ordered mine a few minutes ago. :beer:
scramblr
New Braunfels, Texas
It may dissipate water better, but still love the disclaimer. That's why I'm stuck with 555r's as a daily driver.
"All Mickey Thompson ET Street Radial tires are designed for drag racing use. While Mickey Thompson ET Street Radial tires meet Department of Transportation requirements for marking and performance, they are recommended for DRY PAVEMENT USE ONLY."
tigerhonaker
TN
As you say that is actually true but I can tell you many-many people are driving on the street with the M/T ET Street Radial II tires for sure.
I have wore-out Google Search researching these tires.
And they can be driven in the rain until they wear down.
I think it just really comes down to a "Common-Sense" sort of thing running these tires.
If they are practically NEW and it is Raining, Not-a-Storm then Slow your Butt down and drive right on.
Pouring-Down and or a Storm one might wish to do the 4-Way-Blinkers and Slow-Their-Ass way the hell down.
It all comes down to what a person is willing to make work for their application.
These tires are not for mileage.
Their not for driving in the winter.
Nor driving in pouring down rain with standing water in the traffic lanes.
But, they damn sure are for High-H/P Street Cars with the Newer 20" Wheels.
If that person can afford to run with them !!!
Terry
19COBRA93
Ford Racing
Clinton, Ut
I am running the MT's in a 305/35/20, and they are awesome. 800hp and they really hook killer.
chandlern
Royal Palm Beach, FL
I'm running ET Street II's on my 05 in 305/35/20. Just what I wanted, hooks great when its dry and if you get caught out in the rain. Wear on the tires is great so far, have about 3k on them and haven't noticed appreciable wear or change in handling. You wouldn't catch me on the highway in a storm with them...and definitely not doing 75/80 in the rain like the article says.
tigerhonaker
TN
Hey Guys ...
I just did a New Post on a Thread of mine, check it out.
Any and all your Comments & Thoughts are more than "Welcome".
I am very-very interested in anything you can tell me on running these.
I'll be running them soon as you read on my Post.
http://www.s197forum.com/forum/showpost.php?p=1988317&postcount=239
In my case I'm going to be attending what is called, The Texas Shootout in Lufkin, TX.
I live in Franklin, TN.
So I will be cruising with them to TX. from TN.
I (Appreciate) you Posting !!!
Terry aka "tigerhonaker"
BTW,
I have spent Days and Days and Days "Researching" these tires.
I'm going to try them !!!
19COBRA93
Ford Racing
Clinton, Ut
I ran the Nitto 555R's last year, and these MT II's are FAR superior. If I short shifted into 2nd, I could burn those Nittos for 200 feet. These MT's, they'll spin a bit in 1st, and just a bit on a hard shift into 2nd, but otherwise they just dig in and go. Doesn't matter how cold the road is, or what type of surface it is. It's pretty amazing. I'm actually worried about my clutch now. Even if they do spin, they're still digging in and pulling. When the Nitto's would spin, I'd have to let off, let them bite, then get in it again and maybe they'd hook.
They are wearing very well too. They just don't really spin, so that saves them. I try to stay out of the rain, so I have nothing to share on wet handling.
tigerhonaker
TN
Sam,
Thanks man for your input. :beer:
I was hoping maybe one of you had driven in the rain some with them.
I completely understand trying to avoid it if possible.
But, in my case I might run in and out of it traveling through multiple states.
I have ordered them this afternoon so they are going on and I am going to give them a try.
I have used so much caution and backed off on doing them last year but this time I'm in.
I figure either I like them and can drive with Caution when it is raining or I can't.
So ........
My butt is finally getting off the fence-post and doing my thing. :beer:
I do know from all my research on multiple Internet Sites the guys with CTS-V Cadillacs, Vetts, and other real High H/P cars do run them.
Terry
19COBRA93
Ford Racing
Clinton, Ut
I wouldn't hesitate running them in rain if that were to come up. The grooves are plenty deep.
skwerl
tree hugger
central Florida
I would run the MT's if I could find one to fit an 18x8.5" rim and was taller than 27". Best option I could find is the M&H Racemaster in a 275/45-18.
chandlern
I don't think you'll be disappointed. I switched to MT IIs from Invos and it was a definite upgrade. About the same in the rain, wet pavement is ok I just stay out of boost and if there is a lot of water on the road I'm off the loud pedal, but it was the same with the Invos. Dry is where the big upgrade was, just as stable in the corners and braking but it doesn't matter if the road is hot or cold, clean or not so much they hook, to the point of me worrying about breaking stuff elsewhere. The Invos would spin if it was cold or at the hint of debris when on it in second and third. The car makes 480/470 and is purely a street car, not much input for track experience here other than they were stable up through 130/140mph when I went to a roll racing event with the local mustang club.
scramblr
Hmmm...tempting, but I just switched to a 15" rear wheel so these are out unless they make them in 15" in the future.
tigerhonaker
TN
Hello Sam ...
Thanks for your post and information.
It is definitely "Appreciated" !!!
Say how many miles do you think you have on your's now ?
And also how do you drive with them, usually on the street ?
(Meaning, Balls to the Walls every take off or more subtle)
I'm attempting to ask how do you drive on the street with the M/T tires ?
What H/P & Torque are you running on the Street-Tune ???
Also, you have a Manual or Auto tranny ???
I'm trying to get a better idea of the Bigger-Picture on your Mustang and the way you drive on the street.
Chandler ...
Thanks for talking about the RAIN and driving with them.I figured it was more just a Common-Sense thing dealing with Rain.
How many miles now do you have on your's ???
Have you ever driven with them on long trips like say 1,000 miles round trip ???
I see your H/P & Torque numbers and mine is I think probably around 600 at wheels.
Can't say for sure as I don't have it back yet from Brenspeed in IN.
Brent White, (Owner) has not had it on the Dyno yet to do the Final-Tuning.
Everything should be completed very soon by at least the 31st of this month.
That's why I went a head an Pre-Ordered the M/T tires from Discount Tire the other day.
I will not have much time to get the New Tires on once I get the Bullitt back Home from Brenspeed.
SO MAKING sure the tires are here at Discount Tire so all I have to do is run over to them and get things done.
Sam & Chandler,
Guys I Thank both of you guys for your information on the M/T tires.
If either of you think of anything else please post up as I am interested in what you have to say.
Say, do either of you have some GOOD-Pictures of your Mustangs with the M/T tires on them ???
Links will be fine or Post Pics here if you like.
I would Luv to see what these look like on our Mustangs !!!
chandlern
No problem Terry, they're a little spendy but worth it if for anyone planning on actually using the power they make on the street. If you don't mind me asking what'd you pay for them through discount? I bought mine from Summit (380$ +/-) as it was the best I could find.
You're correct its pretty much common sense in the rain. At the moment there is probably 3 or 4k miles on them now, no changes in traction or noticeable wear, though I'm sure if you measured them you'd see it, still plenty of tread life left. I guess you could call my driving aggressive, but no burn outs on them just dusted them off a few times.
Longest trip on them was a 9/11 memorial run down to the keys and a car show with my local club, probably 700 all together without any problems, minus it pouring the last half hour before getting there, guys on street tires sliding around all around me. Good long weekend, took home best 05-09 and got engaged.
I'm sure I can find a picture or two to post up! Just let me get to the desktop.
