tranny keeps grinding at high rpms
turbo_mustang12
I have a 2005 mustang 4.6 3v.This is my 3rd tranny and 3rd clutch. Whenever i try to down shift it grinds or at high rpms. I have changed the shifter and most components around the tranny. I have just installed a Mcleoud rxt clutch and flywheel and a rebuilt tranny and same thing. Any suggestion will be greatly appreciated thanks
fdjizm
Drag Queen
NY/NJ
Che torque limiters and prothane mounts. Also our 3650 synchros suck!
weather man
Persistance Is A Bitch
MN
Keep your eye out for a cheap TR-6060.
turbo_mustang12
Thanks guys will check that
Will the tr6060 or any of those 6 speed transmissions work with my mcleoud rxt clutch? I built the motor with an teksid block so I have a 8 bolt crank now.
You will need to change the clutch discs from 10 spline to 26 spline.
JoshK
Modder AKA Fuel
Nebraska
You can send back to mcleod and have the clutch rehubbed if it is low enough miled
johnnyv8
South Jersey
I went through two tr3650 and when I literally blew up my 3rd gear on a short pull, I scoop up a tr6060!
RetroGT2006
06 S197 Member
Florida
Where can you find 6060s at and what is the price including DS? I am having no issues with my 3650 I just put in but if it ever blows up I want this to be my next swap.
I was a rare one as well, I put 35k miles and lots of dyno passes and track passes at 650-700rwtq revving to 7k rpms and had no issues with my 3650, none at all. ;) But I still made the switch to the 6060 after all that... and I lost 4th gear synchro in the 6060 already...lol
AutoXRacer
My TR3650 was flawless...I pulled it out at 64K miles to make room for a brand new drivetrain (new motor with T-56M XL).
07 procharger
Addicted to modding
Red Deer Alberta
My 3650 owed me nothing. RST with CHE torque limiters spraying a 200 shot on DR's
3rd gear proved to be the weak point
Problem solved.
turbo_mustang12
so i should start off by buying the che torque limiters? Also does anyone know why I cant post in the classifieds?
07 procharger
Addicted to modding
Red Deer Alberta
My limiters are sitting on my shelf. You cant post because of yopur post count. You need to contribute more to the forum.
