Maximum Motorsports S197 K-member and SLA???
Mineral_'01
You guys should probably have a look at this if you haven't already seen it. Very interesting, I sense a possible SLA suspension setup in addition to their new K-member.
A lot more pictures and info here:
http://www.svtperformance.com/forums/showthread.php?1039173-Maximum-Motorsports-K-Member
I'm allowed to post links to other forums right?
Edit, new info released from maximum. Taken from the thread above:
Maximum could have made it weaker if they wanted to. Thankfully, they didn't. There are any number out there that you can twirl on your finger if that's what you're after.
Here's a breakdown they were generous enough to provide in advance of release. Thanks again Chuck, Luka, Jack, and everyone else at Maximum!
Design Goals
When it comes to the k-member, we feel that improved geometry and strength/stiffness are head and shoulders above all other considerations. For the S197 k-member we put not increasing NVH at the secondary level. Reducing weight comes last because it is nearly impossible to reduce weight without also reducing strength and stiffness. Since the k-member supports the entire front suspension while also holding up the engine, we feel that simply in the interest of safety we need to maintain a particular level of strength. If one is serious about weight reduction, we feel it should be done by reducing the weight of something that is not a mission-critical part, as the k-member is. Fiberglass or carbon fiber body panels are our first choice. This does not mean that we ignore weight-saving, as one can readily see from the lightening holes in the k-member. We do what we can, as long as we are maintaining our desired strength and stiffness.
This k-member is not aimed at drag racers who want to save weight at any cost. We know the majority of our customers are using their vehicle on the street, with occasional track events. Durability and low NVH are their primary concerns. Most of our Fox/SN95 parts were designed for street driving, and then tested and proven on racecars. We followed the same path when we designed this k-member.
Strength/Stiffness
With the S197 strut suspension design, most of the cornering loads are fed into the forward control arm pivots on the k-member. The highest loads at the rearward control arm pivot mounts of the k-member are during heavy braking. We focused on making the section forward of the rear pivots stiffer than the stock k-member. We also concentrated on feeding those loads primarily through the upper frame rails.
We built two fixtures to load test the k-members. The MM k-member deflected 30% less than the stock k-member during a simulated cornering load. We tested one aftermarket k-member, and it deflected 40% more than the stock k-member did in the same test scenario.
NVH
NVH is increased by using non-stock motor mounts. Many people complain of excessive vibration, especially at ide, when using urethane motor mounts. Some NVH comes from non-stock FCA bushings. These cause more of an increase in impact harshness than vibration. NVH is certainly subjective. What one person finds acceptable for daily driving another considers intolerable. In our opinion, the S197 is far less tolerant of changes that affect NVH than the previous generation. Bushing changes that cause unnoticeable or minor increases in NVH on a Fox/SN95 chassis cause big NVH increases with the S197 chassis.
Motor Mounts
Over the past several years we heard many complaints from people about increased NVH, primarily caused by the proprietary urethane motor mounts used in their aftermarket S197 k-member, regardless of the manufacturer. We also heard from our dealers, and other installers, who disliked having their customers complain about increased NVH after installing a k-member.
Through the building of a couple of iterations of our first design, one of which is on the yellow Vortech SEMA car, we encountered many design issues trying to route tubes around the stock motor mounts while also offering two control arm mounting heights. When MM’s head design engineer, Luka, had the idea to make machined aluminum blocks to lower the top mounting flange of the k-member, those difficulties went away. As a bonus, by mounting the motor mounts to the aluminum blocks, the engine could stay in its stock location even when the rest of the k-member was removed. That greatly improves access for maintenance and header installation.
Aluminum Blocks
Each aluminum block is aligned to the frame rail with a close-fitting pin that fits into the same hole in the frame rail that Ford used for alignment on the assembly line.
The k-member mounting flange has over-sized holes to allow shifting it relative to the blocks, allowing precise squaring because it can move more than the stock k-member can. In the event that even more movement is needed, the pins can be easily removed from the aluminum blocks to allow shifting the blocks on the frame rails.
The blocks were designed to place the top of the k-member below the pinch weld on the underside of the frame rails. This lower position allows the k-member to be adjusted without running into the pinch welds.
Yet another bonus: The blocks were designed to provide an accurate mounting point for the upper control arm of an SLA suspension. We are still in the testing stages of our design and have no planned release date.
FCA Height
We did not send Tob spacers for the rearmost front control arm mounts because we knew he would not be using the upper set of holes. For extreme lowering, when moving the FCAs to the upper set of holes would be beneficial, several things are required. Spacers are needed to move the rearmost FCA mount upwards to match the front mount. The stock rearward FCA bushing must be replaced because its large diameter would interfere with the frame rail; smaller diameter aftermarket bushings of either Delrin or urethane are required. Bumpsteer must be addressed by installing a bolt-through bumpsteer kit. The stronger bolt-through style is required instead of the tapered stud to prevent breakage from the increased load from the extra leverage of the greater length required to properly locate the outer tie-rod end to match the FCA in the upper set of holes.
Anti-dive
We did not alter the angle of the FCA pivot axis because we did not want to significantly change the stock anti-dive percentage. The act of lowering an S197 will cause an increase in anti-dive. With the stock k-member, lowering the car one inch increases anti-dive from about 15% to about 20%. With this MM k-member, lowering one inch with the FCAs in the lower set of holes also increases anti-dive to about 20%.
We learned 15 years ago through testing that significantly increasing the anti-dive of the Mustang strut suspension caused a bad effect that far outweighed any beneficial effects: Encountering even small bumps during heavy braking would easily cause front wheel lock up.
There are two main reasons why increased anti-dive worsens braking on an S197 chassis. First, and this applies to all cars, as anti-dive is increased the resulting suspension geometry causes the tire to move more forward with bump travel. This makes the slope of the bump steeper, increasing the vertical acceleration of the tire, bouncing it off of the ground. Second, the geometry required for increased anti-dive increases the bending load on the strut. This increases friction in the strut, causing poor compliance of the tire to the road. This second problem is missing from an SLA front suspension because it does not have a strut.
Bumpsteer
A bumpsteer kit is required with the MM k-member. The stock front suspension has the usual Ford design of a small amount of bumpsteer (toe-out under compression) to promote understeer. Raising the inner FCA pivot points requires changing either the inner or outer tie-rod pivot points to match, just to maintain the stock bumpsteer (toe-change). The easiest way to do this is to use a bumpsteer kit at the outer tie-rod end.
Front Control Arms
We are not in a hurry to make our own. The 2010-14 Ford arms, with the larger ball joints, are very robust. A lighter weight arm would likely not be as strong and stiff.
Floorpan Distortion
Until this thread we had not heard of floorpan distortion at the rearward mount caused by anything other than incorrectly jacking up the car at that point. We also have not seen any permanent floorpan deformation on any of our test cars, driven both on the street and on track.
We knew of the k-member rear leg failure shown in a photo posted in this thread, and designed a strengthening brace for the rear k-member mount. We did not include it on the first pilot run of k-members because it would have added 2-3 lb. We are still discussing making it an option; not choosing it would still add weight, but well under 0.5 lb.
Steering Vibrations
The advent of the electric rack in 2011 brought both good and bad. The stock EPAS anti-nibble programming was based on the stiffness of the stock rubber FCA bushings. Replacing those bushings with stiffer urethane or Delrin causes the feedback loop in the anti-nibble programming to become unstable, causing the system to oscillate. These oscillations are felt in the steering wheel as vibrations. By allowing the use of the stock control arm bushings, we are able to minimize any EPAS steering related issues until a solution cheaper than upgrading the rack can be found.
Material
All tubes are mild steel DOM tubing. The main tubes, on the lower plane, are 1.75” diameter with a 0.095” wall thickness.
The Envelope
We maintained the same ground plane as the stock k-member. The other tubes are located to provide more clearance towards the engine, exhaust, etc., than does the stock k-member.
Weight
Yes, it is heavier than a stock k-member; 42.54 lb vs. 40.52 lb. We tried, but upon meeting our design goals, this is where it is. Handling is improved. Stability and predictability are improved; the front end feels much more… Planted is the best word for it. There is less front-end drama when cornering. Maintenance and header installation is greatly improved. Someday an easy SLA upgrade will be possible.
Radiator Core Support
We have finalized the design. Production fixtures will be built once the k-member is steadily rolling off the line. It is a fair bit lighter than the stock core support. Provision for a stock-location swaybar mount is an option, as well as mounting points for a splitter.
Forward Braces
These connect the MM core support to the MM k-member. They add stiffness to the front end. The swaybar mounts are located on the braces. The braces include a provision for shifting the swaybar pivots fore/aft to better align the end links on adjustable front swaybars. The design is not finalized.
Engine Support Beam
We’ve designed a reasonably cheap tool to greatly aid in the installation of the k-member. When using an engine hoist to support the engine during k-member removal, the legs block access to the underside of the vehicle. Our engine support beam spans the strut towers and uses ratchet straps to temporarily suspend the engine while the k-member is swapped.
Availability
Mid-November. The design is finalized, except for perhaps adding the option for the rear mount area brace.
Pricing
Still TBD. Should be finalized within two weeks.
sheizasosay
Alive
Wow...how cool is that? Great idea to provide a means where you can support the engine and drop the k-member. Smart. Alternate pick-up points for the control arms and alternate pick-ups for the different steering racks. I imagine this will sell well.
CPRsm
^^^^ Good part is a good part. He's probably most impressed they didn't copy BMR lol
DRock
Sweet looking piece. Just wished it dropped a few pounds also
Mineral_'01
Edit- Where is the SLA info? Did I miss it?
There isn't any info about the SLA portion of the billet blocks yet. I hinted at the possibility of the extra mounting holes on the blocks as mounting points for a SLA setup in the other thread linked. The OP responded with a wink, as to not reveal any details about it just yet. There can be only one reason for those outside mounting points.
I just hope when it is released, it can somehow use the stock spindle. I am pretty excited to see how this turns out. This is one of the most innovative products for theses cars I have seen in a while. Well other than what Kelly is working on over at BMR (watts link) if they can get it on the market.
csamsh
OKC
Why do we need SLA? Will it improve lap times? What racing series/classes would it be useful in?
Mineral_'01
I guess perhaps we don't really NEED SLA, but having a better camber control/contact patch under certain loads or roll may result in better lap times. Not sure where this would be legal and what series or class, but it is certainly "cool" and who doesn't like spending hard earned $$$ on cool go fast parts.
Boaisy
Dark Knight
Memphis, TN
Wouldn't SLA mess up the EPAS system if it already goes berserk from bushings? If so, people without the "fixed" EPAS would have to spend even more money for the SLA.
Mineral_'01
Possibly, but I thought the 2012+ S197's had the revised EPAS software version where this is no longer an issue.
Edit:
I also want to make the point that I am only assuming that those special billet blocks were machined with a SLA setup in mind, I cannot confirm it. There is almost no other information online about this K-member anywhere. I couldn't come up with any other reason for those outer attachment points on the blocks. I guess we will have to wait and see. I am thinking it's going to end up with a design similar to the Agent47 SLA setup as shown.
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
Don't get me started on the EPAS problem that Ford knows about and allegedly fixed in later models. The fact that they refuse to release a firmware update and instead expect me to shell out a thousand bucks for an entirely new rack to fix their fuck-up just makes me angry. :rant:
skwerl
tree hugger
central Florida
I've only been around the Mustang forums for 4 years. Can somebody please tell me WTF is SLA?
oh I know. I'm afraid to do anything in the FCA area because of that.
Also, WTF is FCA? I know some people here love using acronyms but just because you make one up or read it in a magazine article doesn't mean we all know what it means.
Whiskey11
SCCA Autoscrosser #23 STU
Short-Long Arm. It's a double wishbone setup. Basically the front roll center is far more stable, better negative camber gain during body roll that keeps the tires flatter to the pavement for less tire wear and more grip.
The Mustang front suspension is a strut based suspension. Struts lose camber at an atrocious rate, which requires more camber at static ride height and more spring rate and ultimately have less grip.
skwerl
tree hugger
central Florida
Thanks! I think I got it now.
http://lmgtfy.com/?q=SLA+automotive
FCA = A-arm/Front Control Arm. I was too lazy to type it, MY BAD.
Dude can be a real asshole and a dick, lol, jk.
Yes, I am. :beerdrink:
That's why I don't talk to my neighbors.
Mach2burnout
05 Redfire GT
Central Louisiana
Brian, SLA is referring to Short/long Arm front suspension, or the traditional suspension under cars that do not have macpherson strut front suspension.
Not sure about the FCA
Sent from iPhone
Vorshlag-Fair
Official Site Vendor
Dallas, TX
Good question, and one worth exploring...
Let's look at some examples of McStrut vs SLA: the 3rd and 5th Gen Camaros had McStrut fronts, but the 4th gen Camaro had SLA fronts. Was the 4th gen fundamentally faster than either of those other Camaros (ie: better handling) or an S197 with McStrut front suspension? (the answer is no) Did they ride fundamentally better? (again, no). Having owned, driven, and/or raced in all of these chassis I can say this. Currently the 5th gen 1LE Camaro is winning at the top levels of SCCA Solo, racing against older Camaros (virtually gone) and the late model S197.
The 4th gen chassis (SLA with a coilover and tubular K-member conversion shown above) was designed to have a SLA front end, but technically it was a re-hashed 3rd gen McStrut tub that was redesigned to fit the SLA. Like with this car, there will always be geometric constraints that lead to compromises when converting a McStrut car to a double A-arm or SLA front suspension. The frame, strut towers and other items get in the way of making nice, long control arms.
That's a double A-arm set-up we're building for a 2nd gen MX5 using C5/C6 Corvette spindles. The spindles are 5.5 pounds of forged aluminum and the arms are nice and long... but if we could cut the frame we'd make the uppers even longer, for better camber curves. This car came with double-A arm suspension and had more room than most, but the engine bay is narrow.
The goal of a double-A arm or SLA front suspension is better dynamic geometry. A Corvette chassis is built in such a way as to have really long A-arms and excellent geometry (camber curves, bump steer, caster, etc). Its hard to do that "after the fact". The trade-off is: high cost and worse packaging. The engine bay in any Corvette is rather narrow compared to the S197. If you want wide tires with real double A-arms, that's the trade off. The double A-arm Miatas all have a fairly narrow engine bay as well as VERY narrow tires. Its a packaging constraint. Everything depends on everything else - racing is all about compromises.
A McStrut front suspension is GREAT for packaging, and you can get a lot of tire under the fender and still fit a really wide motor under the hood (like the Ford OHC V8s). Sure, the camber curves are less desirable, but they are better than the double A-arm cars of the 60s-70s. Yes, you have to run more static negative camber with a McStrut car. But virtually nobody designs a scratch-built race car around McStrut suspension, however. The goal is always A-arms.
All that said... Maximum looks to have made a nice set-up and I await some testing by racers to see if this picks up time and/or by street guys to see if the ride improves. I'm sure they have done their homework and there will be a benefit from this (likely costly) set of mods. :beerdrink:
