new PB, 24OCT14 test and tune @ MIR, 2005 mustang GT
lindertw
NoVA
24OCT14 midnight madness/test and tune @ MIR
2005 mustang gt
20,xxx miles, K&N CAI, steeda udp's, frpp shorty headers, stock h-pipe and cats, frpp GTA mufflers, 5spd manual (stock trans/clutch/shifter)
93 street tune - Woodbine Motorsports
302 rwhp / 317 rwtq
strange single adjustable front struts, gt500 strut mounts, cobra jet front springs (m-5300-q), front sway bar and bracket removed, UPR radiator support, stock 2pc drive shaft, front/rear drive shaft safety loops
metco UCA/UCA mount/LCA's, pinion angle set to -2 deg, strange single adjustable rear shocks, cobra jet rear springs (m-5300-q), frpp bump stop kit, comp engineering adjustable panhard bar, comp engineering pandhard bar brace, BMR relocation brackets, frpp 4.10 gears, LPW diff cover, eaton truetrac diff
15x4 Weld RTS with M/T ET fronts
15x8 Weld RTS with M/T ET street bias ply rears
UCA in upper hole on UCA mount
LCA in middle hole on BMR relocation brackets
front struts full loose
rear shocks +7
15psi cold rear tires
6500 rpm clutch dump off the limiter
the change(s) made for last night's runs:
- removed passenger seat and rear seat back/bottom
- short accessory belt, bypassing the power steering pump
- insulating wrap on the cold air intake where it passes over the upper radiator hose to keep temps more consistent.
3490 lbs race weight with driver, helmet, 1/8 tank of gas, gutted trunk, pass seat and rear seat back/bottom removed (3265 lbs w/o driver and helmet)
pb 60 = 1.611; 1/8 = 7.819; 1/4 = 12.339 DA was between +99 ft and -299 ft throughout my runs per drag times calculator
Spun bad on the third pass after following several street cars that drove through the water box
I missed 2nd gear on the last pass, it may have bested my 12.339... There's still some tweaking to do with tire pressure and shock/strut settings. I may have a high 1.5x 60' left in the car, and maybe 12.2x ET by years end.
Johnf78
Upstate NY
Damn!! Still with the stock cats and only bolt ons. That's impressive for sure...nice work!!
fdjizm
Drag Queen
NY/NJ
Nice work! you're pushing that bitch to the limit.
lindertw
NoVA
winter plans: bump rev limiter to 6800, urethane diff bushing, and double adj shocks - those should help me knock a few more hundredths off...
conexion914
Great work! You less mods than I, but go faster lol. I have an auto and can't leave at 6500. My car has been 12.48 and 7.9x
fdjizm
Drag Queen
NY/NJ
I can't race under a 1/4 tank I get an interruption when I launch like if the engine shut off for a half sec.
idk how you get away with 1/8 tank on the strip!
lindertw
NoVA
What are the diameter of your ET streets, and what rpm do you go through the traps at?
m/t et street p/n 3752 (26.1" diam per their page) with 4.10 gears. I never look at the tach when going through the traps, but using a calculator the three good passes posted above I went through the traps at just over 5700 rpm.
rpm = (mph x final gear ratio x 336) / tire diameter
