ford20
I just want to say that this will probably be a slow teardown and build as I work on the weekends as well and have maybe an hour a day to devote to tearing this down, plus I have to wait to gather funds for the build since this happened at an inopportune time (not that there is ever a great time for your engine to decide to devour its self).
Well, it seemed as if I had started to develop a tick with my engine. I parked it for a bit to try and figure out what was wrong with it and over the course of a couple of weeks I forgot about it. I couldn’t find the keys to my V6 and started the Boss up and I was quickly reminded of the loud noise emanating from my engine. Anyway, it sounded something like this in case anyone is interested in what prompted this whole process.
http://vid579.photobucket.com/albums/ss233/fordfan7689/20140914_143224_zpsbc3afb89.mp4
Well after that, I parked the car until that weekend and drained the oil. When I did I didn’t notice any metal flakes through the oil so I thought that I was in the clear there. Well, I was wrong. When I was draining the oil from the drain pan I noticed a couple of sparkles coming from the oil and that’s when I noticed everything.
The next step was to take the engine out of the car. It was pretty straight forward, the only real hiccups that I ran into was that I rounded off one of the bolts from the exhaust manifold to the cat so I removed the clamp that connects the cat to the midpipe. The starter motor has a bolt on the very top of it that is a pain to get to from under the car or from the side of it, so what I did was put a couple of extensions together and attacked it from the front of the engine where the A/C condenser was. The biggest problem was actually getting the engine free from the transmission. When it came time to pull the engine it just wouldn’t budge, eventually after a lot of up and down with a jack and the engine hoist I got enough daylight to finally get the very tip of a screwdriver in between the bellhousing and the metal plate and use it somewhat as a wedge to finally break it free. I decided to remove the hood to make it a lot easier to actually pull the engine from the car.
I had the engine in this position for a while until I was finally able to get the away from the transmission.
After about 2 hours of up and down and back and forth and getting the screwdrivers around the bellhousing out it came.
The obligatory (not so) empty engine bay shot
Parts List
Parts List
- 2013 GT500 Cooling Fan – Part# M-8C607-MSVT
- Aeroforce Interceptor Single Gauge – Part# CN101
- Aeroforce Black Bezel –Part# AF-BEZEL-BLACK
- Aeroforce Black Boss 302 Gauge Face – Part# AF-LOGO-BOSS302
- Aeroforce 5V regulator kit – Part# AF-SENS010
- BMR K-Member - Part #KM018
- BMR Tubular A-Arms – Part # AA021
- BMR Radiator Support – Part # RS003
- Kooks Long Tube Headers 1 7/8ths – Part# 11412400 Supersedes Part #60-41-188
- McLeod RST Clutch with Lightweight Steel flywheel Package – JPC Racing Part # 1124
- Moroso Race Oil Pan – Part # 20572
- Oil Pan Gasket – Part# BR3Z-6710-A
- Oil Pickup Tube – Part# BR3Z-6622-A
- Oil Pump – Part# BR3Z-6600-A
- Roush Vent Pod – Part# 404470
- TSS Billet Oil Pump Gears – JPC Racing Part # 1760 (It may be the same as TSS’s but I couldn’t find a part number on their website)
