my HID Retrofit
Saleen4971
Indy
its been almost 2 weeks since ive started driving the stang, and my god do i miss the HID lights i made in my jeep.
luckily, i had some stuff laying around so i ordered a few more parts, and have been working on it little by little for a few days.
used aftermarket housings, as OEM is permaseal.
first try, mounting projector in front of reflector bucket. left too large of a gap, and you could see behind the shroud :/
today i took some measurements, figured out i could most likely fit them mounted from behind. sooooo here we go...
temp mounted in the housings for some beauty shots :D
hopefully i will be able to finish them up tomorrow, but we shall see
Johnf78
Upstate NY
Those are looking good! I look forward to seeing them on the car. Nice work :thumb:
Shotokan1509
CT
Interested to see the final product, most retrofits I've seen look googly eyed or projector too small... yours with the reflector still behind but inset projector has promise
RedfireV8
Denham Springs, LA
Yay! In for the progress!
I was just going to ask if you were going to make a thread about this. Started thinking of doing this myself just last week and started doing my research. I was thinking of the 3" projectors as well since 05-09 headlights are so big, figured the 3" would fill it out better. Definitely interested in what wiring harness you went with and exactly how you wire it up. I have a couple ideas how to go about it but would like to see how you do it.
Oh and everything looks great by the way!
Saleen4971
Indy
when i woke up this morning, it was overcast and fairly dark out. of course now that i got the headlights in to check alignment, its bright :/
Saleen4971
Indy
well for now they arent sealed up - i need to check horizontal and rotational aligntment before all of that - i think i screwed the pooch on alignment but we shall see.
im used to the huge one piece housings of my grand cherokee, that are easy to figure out :/
irishpwr46
Official Site Vandal
NYC
in for results. i have factory hids, but the projectors can look so much better
Saleen4971
Indy
they will be even better when i upgrade to 50w ballasts and CBIs
oh, and when i put my LS460s in the fogs....
irishpwr46
NYC
as long as they dont look like the raxiom '10 style that AM sells
cavero
NoVA
I completely agree on the googly eyes (that's why I went with my Saleen kit) --and I agree that this one is definitely looking a lot better since the projector lens is recessed far back into the reflector dish. Can't wait to see what this looks like on the car
Saleen4971
Indy
fin!
a few pics of checking alignment, did some minor adjustments (minor meaning, at first the cutoff hit the ground about 7 feet in front of the car......) then tightened everything down, put some steelstik in place to ensure everythign held. ended up having to trim one of the shrouds a little bit, and the other one a little more.....oh well.
that was one long sentence.....anyway - pictures!
i will get some daytime shots tomorrow, probably after i cleanly install the harness.....
