X
xvesnfpu
Guest
Look, I know there's other threads on belt slip, but I want to hear the answer to my question as it pertains to my current issue after my Whipple supercharger installation.
What are ALL of the symptoms of belt slip, whether mild or extreme?
Here's the scenario, after about an hour of driving, with a few wide-open-throttle runs, and otherwise normal driving behavior I experience some issues. Specifically, I lose all boost, loss of the audible supercharger whine, and the problem persists and worsen to the point that I may develop engine hesitation, rough idle, stalling (only once), and even a check engine light. If I let the engine cool overnight and disconnect the battery for a short time, the check engine light and symptoms seem to disappear but reoccur within an hour of driving.
I don't know what belt slip sounds like, and trying to describe it is hopeless. Without an audio clip, I just don't feel knowledgeable enough to confirm the noises I hear are belt slip. I did destroy a belt the first couple hundred miles after installation, and am now on my 3rd belt. The current belt was replaced out of desperation. I have one additional belt just in case. The best I can offer is that when the problems become apparent, the audible supercharge whine disappears, and a "noise" of some kind seems to appear. Yes, I have belt dust everywhere, but so do others, and none have complained of the issues I'm experiencing.
I have tried varying the position to the adjustable idling pulley. I've positioned the belt tensioner to its extreme and tightened the adjustable idling pulley to its extrme, and I've positioned the belt tensioner to its midpoint and the adjustable idling pulley to its midpoint as well.
I do not have the capability to verify the code on the engine light just yet. I plan to purchase a Diablo or SPC flash device in the next week.
Originally I thought belt slip only led to an audible noise, but can the problem worsen to the point that the engine experiences the symptoms I've described?
Is there a way I can confirm I'm experiencing belt slip and nothing more?
I'm lost at this point, and without someone more knowledgeable than me, the problem just wont go away.
