Procharger P1SC H.O. tuner kit for 2005-09 GT
hotrod_renegade
Captain Hindsight
MANtana
SOLD!
Up for sale I have a Procharger P1SC H.O. Supercharger tuner kit for 2005-09 Mustang GT. I bought it used from another member on this forum a few years ago. It actually has a 12-rib pulley setup, which is a little overkill for this system but that’s how it came when I bought it and it works. Comes with two supercharger pulleys: 3.33” (12-13 lbs. boost) and 4.25” (7-8 lbs. boost). I personally ran the 4.25" pulley, which was good for ~7 lbs. in 5300' of air. All the necessary piping, couplers, brackets, fasteners and clamps are included and will be labeled and bagged individually, plus a brand new 12-rib belt from procharger.
Things you will need to make this setup complete:
- Cooling system upgrade kit for 2005-06 cars
- Slim fan to make room for the 12-rib setup
- ATI Superdamper and ARP Damper bolt (part# ARP-156-2501, $28.49 from Summit). The stock bolt cannot be used with this damper.
- Injectors
- Boost-a-pump or aftermarket fuel pump setup
- MAF extender or bigger MAF sensor
- Tuner and a tune
A few other notes:
- The finish on the piping is not perfect, there are scratches and scrapes. A good powdercoating would make them look nice if you are picky about appearance.
- The intercooler does have a few dents in the fins on the front sides from being mounted. It was like this when I bought it, and does not affect the performance of the intercooler. Can be seen in pics below.
- The outer shoulder of the 4.25" blower pulley is dented in on one side. It was like this when I bought it. I ran it like this for 3 years and had no issues with it on the belt. Can be seen in pics below.
- The underside of the tensioner is scratched up a bit due to me having it set incorrectly and the belt rubbing on it when I first installed it. It's not noticable once it's installed as it's on underside of the tensioner. Can be seen in pics below.
- The I.D. tag on the blower is faded, but the serial # is still visible. Can be seen in pics below.
None of those affect the way the kit performs, but they are there and I felt they needed to be pointed out.
Asking $2500 + shipping. I had this listed as a complete turnkey kit, but after a couple of months with no sale I parted out the balancer, injectors, fuel pump, slim fan etc. If you're looking for any of that stuff I have it listed in a separate thread here: http://www.s197forum.com/forum/showthread.php?t=129237
Cancun
Hey there,
What would I need to do in order for this kit to fit my 2010? Would I need a whole new bracket assembly or something?
And btw, is the IC the 3 core model? Thanks.
hotrod_renegade
Captain Hindsight
MANtana
Hey there,
According to the Procharger website this will fit a 2010, but I'm not entirely sure otherwise. Maybe someone else will chime in on that. This kit has the 2 core HO intercooler.
13726548
GA
I believe the only difference among the years, in the context of Procharger installs, is the coolant hose routing and the fuel pump model numbers. Best thing to do is call Procharger and ask. They are very helpful.
Mustang dog
I've got an 07, I'm looking for a turn key kit. What can you setup for me? Inc cost?
hotrod_renegade
Captain Hindsight
MANtana
The ATI superdamper is just about all I have left that would go with this kit, and a few other odds and ends that could also be used for anyone adding a supercharger. The prices and details for those can be found in the separate link at the end of the original post. I no longer have the injectors, MAF extender, boost a pump or the slim fan so you'll need to pick that stuff up. Plus you'll need a tuner if you don't already have that. I also listed everything you'll need, a lot of that could be found used on here so you could still be into a decent kit for little money. I need this gone so shoot me an offer if you're interested.
