Yet another motor down...
ChevyKiller
Preferred Internet Drink
I didn't blow it up but I have learned from experience when something is wrong so I tore this one down before something serious happened...
The car was knocking and getting worse on the dyno with rpm. The car was making outstanding power (over 900 whp) but the knocking was a no-no, so I tore it down.
What I discovered was a first for me. I spent a lot of money on the custom Diamond pistons and there claims of serious boost rings. Well the rings performed as advertised cause they were damn near new out of the box looking after tearing it down. What wasn't good was the oil lands/rings - they were shit and one completely went to shit and caused the piston to knock around in the cylinder which was the sound I heard.
At first, thought I spun a bearing but the bearings, rods, crank, and heads were in damn near perfect condition. It wasn't the one particular oil ring because every single one of the pistons had the oil rings going out and were starting to scratch on the piston side. The one which was the worst was the one making all the noise.
I immediately wanted to look into tuning as that was the first obvious place to look but there was no detonation at all. The tops of the pistons were perfect, the bearings were perfect, and the final inspection was the heads and the are brand new looking. Not a single sign of wear on any of the valves.
I don't need to get into a discussion of what happened because the truth is I will never know for sure but I do know it is one of these three things. Like I said, I'll never know for sure which one exactly, but I know it was one of the three...
#1 - When the bent cam took out my oil pump and I was cranking the car all day trying to start it with no oil pressure, and started it briefly with no oil pressure, the oil rings got damaged being dry
#2 - Diamond Pistons used oil rings on the pistons that weren't up to par with the rings
#3 - The pistons were rattling around in the sleeves causing the oil rings to fail
My set-ups in the past on this motor have been long tubes with a big blower with a loud ass exhaust, so it is possible that this was damage I have had for a some time and just never heard it until I went with the turbos where now I hear everything.
Either way - it is what it is and I was able to salvage everything but the pistons. The block only needs to be very slightly honed for a couple hundred bucks so the bottom line is someone is about to get the deal of the century on a 330" boss stroker motor...lol
The rods are perfect, the crank is perfect, and with a $200 hone job, the block will be awesome so all someone will need is a set of pistons for 330" boss 4.6 stroker. I am going to put an add in the classifieds for it for $2500 so that means all you need is some pistons so someone can get a MONSTER deal on a big bore boss short block.
Here is the block and the thin scratches that will need a light hone...
Here are the Manley rods in perfect condition...
Here is the tops of the pistons looking good...
Here is the sides of the pistons where the failed oil ring caused the damage - all of them are damaged in the same spot slightly - but the one pictured is the worst and the one making all the noise - the cylinder wall pictured was from this piston...
Here is a shot of the heads I also checked for any detonation and were in great shape...
SORRY THE PICS ARE SO BAD BUT ONLY A CELL PHONE TO TAKE THEM
Bottom line - for $3500 or so (after you add new pistons) , someone can get a 4.6 330" boss built shortblock that will easily handle 650-700 rwhp all day long.
For Sale Thread Here... http://www.s197forum.com/forum/showthread.php?t=22092
Before you even ask, the reason I am not simply putting new pistons in this thing is because I only feel comfortable saying this motor is good up to 700 whp and I am well beyond that with my build. I am not dicking around anymore and wasting time with the 'usual suspects' of engine builds. I'm just going to do it right and use custom pistons, oliver billet rods, billet crank, etc, etc. I have turned to the east coast to build me a motor right now and will be finished in about 4-5 weeks. This motor will be built for my needs and my set-up. I am also having my livernois heads re-designed back east and getting a custom cam and all Jesel rockers/followers/lashers, and some other stuff to get my heads were I think they need to be. I'm personally done with the 'off-the-shelf stuff as I feel my power levels have exceeded it all.
With pro NMRA talent stepping into the game to help me build this car, I'm hoping to finally get the chevykiller on the right track to getting 'done'... we'll see...:beer:
US-1
Banned
The ShadowLands
Completely off topic (my apologies).........what did you do for motor mount adapters? I was under the impression that the Boss blocks were set up with the old style motor mounts.
Chris06GT
Dragging LS A..
Alabama
Dang Mark, if it's not one thing it's another......
Glad it didn't destroy itself....And someone is definitely getting a hell of a deal....
Keep us posted on the new motor....
EagleStroker
N/A Junkie
Memphis, TN
We have customers pushing well over 35% more power than you on our crank and rods, unless your just dying to pay for billet pieces :beer:
Good luck with the new motor, seems like your finding weak links everytime you start the car, interesting to see what happens when you actually run it!
ChevyKiller
Really? I appreciate it but I doubt you have customers pushing 35% more than me on a 3V with your products. I made 1026 whp. (with a lot more to go - it was at 26 lbs) You have guys pushing more than that on a 3V?
Damn Mark....... good luck on the rebuild
ChevyKiller
I don't think we used adapters. I'm pretty sure we just modified the prothane mounts slightly.
SD07GT
Did you speak with Adam at ST about this problem to see what he thought of your #1,2@3 thoughts ?
silverstang07
Damn hate to see this happen to that car, its pretty much the "star" of the s197 cars on here! What are you going to do now, Reher Morrison?!?! HAHAHA
ChevyKiller
There was no need to speak with him as it was pretty obvious the oil rings took a shit and there is really no way to know for sure if 1,2, or 3 was in fact the reason - but I'm 99% it's one of the three.
ChevyKiller
Mark, do you have any video of the 330 running?
On the turbo set-up? Yes - there is a couple vids in my build thread. In general? - then there are tons of vids on the whipple and KB set-up and 1/4 mile pass vids.
Miracle
"Shall not be infringed"
Clarksville, TN
Damn Mark... ANOTHER one? Good thing you caught it in time though.
Can't wait to see what's in store for the Killer next.
ChevyKiller
I did have a conversation with him a few minutes ago in fact and it is more leaning towards the pistons rattling around in the sleeves but can't tell for sure yet. I am going to take him the motor next week so he can get a birds eye view and since he is probably going to be the one to rebuild it for someone if they buy it.
Fastmover
MD
Marc I swear you just dicking around with you car until I get mine up and running just so we can race! I think I may get you though, with MY new motor and all! hehe
bolivianpimp
Spring ,TX
Damn that is a monster block. All else needed is that hone and pistons , plus some bad ass cams and heads would be nice too haha
