latch5
Found a reasonable deal. Will there be any problems with F/R brake bias if I use my stock rear set up (05 GT). Any other things to think about?
The bias is fine. You got wheels to clear 'em right ?
The bias is not fine. It maybe fine for the street or a street tire application. But you put those brakes on your car with a race pad and put a sticky set of tires on it as well and your on a time bomb with your abs system. Your abs system is a v6/gt unit tunned .meaning it's tuned for a certain tire grip , certain brake pad grip and a certain driving enviorment. when pushed it could/will freak out and go into a fault mode which is a bad. when this happens bad shit happens. brakes to the floor etc etc. ask around. to make it right you will need a gt500hcu and module. if going full out race I would suggest the fr500s hcu "race calibrated"
a c or s race module will need a gt500 hcu. it will not fit a gt /v6 hcu.
just trying to help.
when the fr500c first came out they had all sorts of weird brake pedal problems, failures etc etc. I've personally seen a few buried in tire walls from it. the fix was the race calibrated modules.
Using Colbalt XR2 pads and Nitto NT 01s now on stock brake system. Do you see a time bomb with this situation. Only problem I notice is hyper heating my front caliper pistons. Needing to find a low cost fix (if possible) - Was under the impression the the GT500 swap was the proper solution. Open to suggestions.
Does anyone know if they make these or any other changes when they put the Brembo's on a 2011 GT Brembo Brake Package. In the description of the package they say "Unique Electronic Stability (ESC) Tuning"?
The bias is not fine.... to make it right you will need a gt500hcu and module..
It's fine for me with Carbotech pads, BFG R1's, and getting into ABS from 150mph so I don't know what you're talking about.
Do as you wish, but I've talked with enough people around the abs system on this car to have a pretty good grasp of what it's all about and it's function.
these are design/engineer guys at ford and outside of ford that designed the system.Not weekend warriors that say no problems with my car.
he asked for opinions and I gave mine.
Why do you think the fr500c and S car both run these items I mention .
I hope that if and when your brakes fail at 150 mph that you get through it.
Are these cars running Brembo calipers on the front and stockers on the rear ? And are you saying that the piston is going to fail eventually due to the ABS taking a crap ? I'm not saying you're wrong but I'd like a little more technical advise other than you've talked to some engineers and seen some cars get jacked up.
What exactly is the point of failure ?
The point of the failure is in the abs unit because your putting information into wheel speed sensors that are not designed to undertand the information your giving it based on pad compund,tire compund etc. etc. etc.
the abs can give up. because of this and it fails. larger pads and different pistons may be the culpret more then upgrading a stock pad but All I'm saying is that when you start changing crap it effects the proper operation of the abs system.
the system has it limits.
as for the gt500 brake upgrade instructions. who knows, maybe the system can handle a 4 piston caliper on a stock pad compund a more agressive tire.
I'm sure when they made those instructions they where not thinking about a guy racing on a road course and burning up race compund tires.
The complete "bleed the brakes" was enough for me to stop reading. You know there is a right and wrong way to bleed a caliper with two bleed screws. They don't even mention that.
Steve speaks the truth...I had my ABS freak out after I put my brakes on during a wet autocross run (wheels locked up, plowed through cones). At the time I wrote it off as a freak incident, but I've heard of a couple other guys running in to this. Never happened again, but I swapped HCU's shortly after. If I can get my shit together and get back out on the track next year I'll be trying out the FR500 module as well.
Most people don't understand just how incredibly complex modern ABS programming is (I will be the first to say I don't know much about it, but I know a little). It can come on even without wheel slip if you're decelerating too quickly; it calculates your rate of deceleration and if it exceeds the parameters that the programming was based on (street tires, pads, etc), it will "think" that all the wheels are locking up, even though your R-comps and race pads are doing just fine. Do something like change up the calipers and you can definitely freak the computers out.
I think the difference between brake boosters, GT vs. GT500, is just feel or assist levels. I think the GT500 booster doesn't give quite as much assist as the GT unit..my pedal got pretty soft feeling after putting the brakes on (that could also be from the increased piston area as well, it's probably a combination of both).
Now if the ABS fails, the tires lock right ? The pedal shouldn't go to the floor. It seems to me this is a MAJOR issue if true which I don't think it is with the Brembo/stock configuration. This combination has been in effect with GT500's and GT's for quite a while now and I haven't seen any failures or revised recommendations from SVT/Ford.
These FR500x cars are not running the brembo/stock combo are they ? I was hoping we could just stick to that combo since that is what the OP asked about and is the same thing I'm running
You may want to order that fr module real soon. least the s one. The mustang challenge series is done this year after miller in September. I'm already starting to see things like the steering wheel , driveshaft loop become obsolete. I'm guessing the module is not far behind.
