I am in the process of swapping out my stock E-force HE for a dual pass Afco unit and could use some input from those who have installed one on either a Saleen or E-force since both have similar hose routing set-ups (passenger side in, drivers side out).
Based on the passenger side fitting location for both the inlet and outlet along with the 90 elbow on the inlet, looks like I need to move my pump to the drivers side along with somehow routing the outlet back to the drivers side. I can probably figure it out, but I know some of you have done this, so hoping to get some insight before I spend too much time trying to make it work.
I bought this slightly used and it came with 2 sections of hose with 90 elbows... which should help along with maybe some couplers to tie these into the stock hoses. Is there anything else I might need?? Looks like the mounting bolts may be too short.
The top/front of the HE also seems to rest right on the rear of the bumper brace when I held it in its mounting location. Is this normal?
Any details, pics, etc would be greatly appreciated
