ethrjock
NEED TITLE CHANGED TO ..with Kenne Bell Mammoth 2.8H
I know we all can't get enough of these build threads so I will do my best to document my build and answer questions along the way (and ask several too). This build out will be completed by me in my basement garage with an average set of mechanical skills, above average research ability and plenty of tools. I research a lot and have done all the wrenching on the stang to date.. I have confidence it can be done by a DIYer especially since the short block is built. My local tuning shop in Atlanta Ga is injectedengineering . Aric Carrington and the Ryans. They are great to deal with and perfectionists like me.My neighbor Mike also helps when I need a third hand.
By day I am a IT Manger, by night, weekends etc I wrench on my stang to push it faster down the 1/4. If I am lucky my daughters will drop down to see what dad is up to and lend a hand and and if I am extremely lucky my wife will keep her patience up during this build while she parks her DD outside ;-(
Enough with the days of our lives crap...We have a lot of work to do...Here we go..
With most projects at the office I start out with stating my goals as to keep me in check with the "end game".
1. Mid 10 second 1/4 (c16 race fuel) with DD tune on 93 pump or E85
2. Street-able with a dual tune (DD and Race)
3. Pickup as many slightly used parts as possible to keep cost down
Major parts ("current build" are items currently part of my 11.6 second mustang...everything else "Oh Hand" is going to be added power in some cases and strengthening parts in others)
A few photos to get started
Dressed up race ready at Hooters Atlanta last summer (not me in the red hat)
Block purchased from Carl in Canada..AKA the b302 block rescued from the fronzen tundra. Great seller to deal with. Saved about a grand from b302 new stock.
I read a lot of guys were pulling the engine/tranny out as a unit. This was the route I wanted to take too. I needed to inspect the transmission ans I swore that i would never pull the transmission again after the last time. That was a fight I tell you what! ..
Here is how I connected my engine level kit. I ended up getting 4" long 10MM bolts to go thru the top 2 bell housing holes and 2 shorter ones for the front of the motor where the water pump housing attaches. The trick here is to get the harness as close as you can to the block.
With a little help from my neighbor she came out in 10 minutes...(assuming all the residual work has been done)
it was close but it came out with the radiator in and the Hood on...I dont have the factory hood prop so my hood was up a bit higher than stock.
It's a BOY!
So I bet your wondering how much time went into this to get this far. About 6 hours. 4 hours disconnecting the various systems (AC, Power Steering, Shifter, Drive Shaft, Starter harness, Intake, Fuel Rails, Mounts)
2 hours getting that harness/engine puller in and positioned like I wanted it to.
10 minutes to pull the engine. I lost a lot of tranny fulid since I removed the speed O module from the drivers side. I thought it was going to hit the firewall on the way out so I played it safe. Looking back I had plenty of room. Fluid came out of that hole.
If you are wondering where I stand on this build.. I am actually catching up documenting this build as I Currently have the block 1/2 way disassembled so in the next few nights I will upload some more photos and cover some of the steps I took that might be more challenging for the average guy. Progress is slowing down since I just ordered the custom cut cams, McLeod RST to RXT conversion requires me to ship the clutch to California etc..etc.
Happy to answer questions...hoping for some encouragement from the forum..
New 302 built stroker shortblock - On hand
- 9.5cr CP pistons
- Manley Hbeam
- Kellog 8 bolt Crank
- I just picked up a KB Mammoth so the Paxton Is SOLD! Getting twin screwed! Paxton HO 2200 Air to Air - Current build with 3.17 pulley at 13.5 lbs of boost on stock bottom, (505 RWHP on pump gas, 550 on ms 109 unleaded) Current build..with all these changes?? Not sure
- stage 3 cnc ported heads Manley 1mm ov size exhaust valves, seals, comp springs and titanium springs.
- Fore tripple with 2 fort GT pumps and 2 single 20amp BAPs
- 3.25" pulley
- Bullet custom grind cams for my blowers
- Livernois/PAC drop in high load valve springs - arrived
- Triangle Speed Shop converted FRPP oil pump with Billet gears - On hand
- ARP head Studs -
- Pypes long tube offroad H - On Hand
- Innovators West 10% OD pulley - On hand
- 8 rib
- Steeda heat exchanger
- 60 lb Injectors - Current...FRPP 80s needed? Not sure yet.
- Morosso Ice box
- Detroit TT -
- Mcleod RST twin and billit flywheel
- Various other suspension mods to get some traction
It's a BOY!
