Check this out
red_baron06
Boost
New Braunfels,Tx
As some of you know I recently put on my saleen supercharger. I soon developed a belt squeak and could not figure out why. Well thanks to S197 forum we found a link that told us to swap the 90mm and 76mm pulleys by the alternator bracket. I guess heres why.
There is 6 groves in the metal, I could not believe it. The best part the belt squeak is gone. Glad to have found the link on here.
cm581978
NJ
have you gotten a chance to take it to the dragstrip yet?
tmcolegr
It's All About the Build
Central, FL
Who suggested changing that pulley to 90mm? The pulley that needs to be changed is next to the P/S pump - replaces the 76mm plastic smooth guided idler pulley supplied by Saleen - not the 76mm metal smooth non guided idler pulley sandwiched between the front cover and the alternator bracket.
red_baron06
Boost
New Braunfels,Tx
I already had the metal 76mm it is now under the alt bracket. The 90mm is before the power steering pump now.
Lupo222
Fort Lauderdale, FL
Not sure what that is a picture of but my install manual didn't say anything about that. In fact, I had two 90s on mine!!! Thankfully oreilys had a 76 in stock and it swapped in fine and my car runs great! No noise!!
dmhines
KONA GT
Cumming, GA
That picture is the install manual from my 2010 Kit ... Says to remove the lower pulley .. and move the upper pulley to where the lower pulley was. The kit included a new upper pulley.
