Anyone running 29.5x10.5 inch slicks?
Robertt305
Anyone running these?
Any former issues?
I just ordered a set and now I'm hearing that there is rubbing issues going down the track...
psfracer
billy badass
Valencia, CA
I am running the 29.5 X 10.5 Ws. You do have to clearance some items---depends on the wheel you are running. The inside corner of the passenger side will be the closest. Do you have adjustable LCAs?
Robertt305
My LCA are not adjustable.
Is it possible to remove the inner fender or do I have to start hacking away at stuff?
I'm running race star wheels
gil_t2
Love Nitro in the Morning
Northern Va
Sounds like a bad combo, How modded is your car and what gears are you running.
psfracer
billy badass
Valencia, CA
10 inch. 5.5 BS
I haven't mounted these yet
Ok, I don't know if you have a narrowed rearend, or something else going on, but a 10 inch wheel with only 5.5 backspacing would stick way out on a S197 with a stock length rearend. Most Bogarts that are 10 wide for our cars are between 7.0-7.5 backspacing, as you only have about 3 inches of room from the mounting flange of the axle to the fenderwell.
Have you already been running those wheels?--or are they new as well?
Robertt305
Stock rear an no they don't stick out... Been using them for a year...
And on the other question I have 4.10 gears and 750 rwhP
psfracer
billy badass
Valencia, CA
Ok, if they don't stick out then they don't have 5.5 inches of backspacing, or they are not a 10 inch wheel.
Robertt305
Well it is a 10 inch maybe I'm confused with backpacking...
It's designed for our cars though with out any fitment issues besides the sway at relocation
Robertt305
Well talked to a buddy running a Goodyear 29x11 r15 D5 with no rubbing issue at all..
This Tire height will do the trick so I ordered it, now I'm off to return the MT's....
psfracer
billy badass
Valencia, CA
Yes, I ran the Goodyear's before the M/Ts---size was 29X11.0 and I had absolutely no issues also.
Robertt305
Sweet!!!
How did they hook for you and what tire pressure do they like?
I think thats too much tire unless the gear is more than 4.10.. If its an auto maybe, stickshift NO.. My .02
