JPC Built 9.97 @ 137mph N/A Coyote Specs
tommygodfrey
JPC Sales & Tech
Maryland
Engine
318ci by JPC/RGR
JPC/RGR Stage II CNC-ported heads
JPC/RGR Custom camshafts
Ford Racing Boss Intake
JLT Carbon Fiber Air Intake
L&M 82mm Throttle Body
Moroso Oil Pan
ATI Balancer
JPC Racing/cp-e™ Return Style Fuel System
JPC 1 3/4" Long-tube Headers and 2 3/4" X-pipe
MSD Two-Step Rev Controller
Stock PCM Tuned by Kevin MacDonald
**550 RWHP
**430 LB-FT Torque
Drivetrain
Tremec TKO-600 Pro-Shifted by Liberty Transmissions
McLeod RST Clutch, Flywheel, and Pressure Plate
Strange 8.8 Spool and 33-spline axles
Strange 4.88:1 gears
Strange adjustable rear shocks and adjustable coil-over struts
JPC One-piece aluminum driveshaft
QuickTime Bell-housing
Chassis
JPC Adjustable Upper Control Arm
Metco Lower Control Arms
Insane Fabrication 8-point roll-bar
BMR tubular K-member and A-arms
Flaming River Manual Rack and Pinion
Kirkey Racing seats
Bogart R/T wheels with Mickey Thompson 28×10.5-inch slicks
Weight
3,030 pound race weight
1.452 60ft
4.139 330ft
6.387 1/8m
109.09 1/8mph
8.333 1000ft
9.975 1/4m
137.06 mph
Video will be coming soon :beerchug2:
white05gt
Illinois
Bad ass setup, never thought there would be a n/a coyote in the 9's!
KonaGT
Maybe they offset ground the crank and did a mild bore?
tjm73
of Omicron Persei 8
Rush, NY
Where did you get the bell housing for the TKO600 to 5.0 block?
You can get a bell housing to put a TKO on a 3V. Since the 3V and the 5.0 share the bell housing pattern, that's an easy one to figure out.
tommygodfrey
JPC Sales & Tech
Maryland
Nice run what's some main factors ti get that weight down that low ????
Basically make it a race car. Now it's no BODY IN WHITE that's for sure it's a real deal 2011 bought new in 2010. We approached this car like we would any of our heads up cars because that's what you have to do if you want to lay down the numbers. Still has all the functioning lights ect. but it's gutted and cut up but it does have carpet and seat delete stuff like that. The OE dash and steering wheel is all in there not a chopped up looking car by any means. I'll put up some pics today.
Congrats guys, Looks like K,Mac did a great job tuning the beast.
Kevin Macdonald is an unbelievable tuner. Don't get me wrong there is still more left in this beast. We still have to work with the cams ect. Kevin has now tuned the Quickest and Fastest Stock electronics 3v (Justin's 2005), Quickest and Fastest Stock 3v Engine(long block) w/stock electronics (His Coupe) the Quickest and Fastest N/A Coyote (Joe M 2011) and his Lightning is sick fast (Stock engine w/2.3 Whipple more than full weight 11.20's.
I see the motor is 318 Ci. What compression is It?
It's higher than stock but didn't have the timeframe to get a spec on it due to getting everything done to make the last races :(
JPC of course we sell parts guys and we have good prices if noone has checked lol
Good question, but what about that 318ci coyote block. how did you guys got 318 ci Cylinder Bore or crank maybe both?????
Both
this is an easy answer...Rich Groh. you get what you pay for!!!
If you want records, horsepower, quality and technology that works he's the man!
Would love to see the dyno graph.
Pics coming, dyno graph coming ( we're going to pull it again soon also) keep in mind this motor was on it's 4th pass it's still getting happy. And video should be up today
