As a continuation to this thread on the Walbro dual channel single stage 39/50 armature turbine pump, as you may know the "465lph" e85 version has now been released.
http://www.s197forum.com/forum/showthread.php?t=74652&highlight=walbro+400
Justin at FORE did some in house testing yesterday on both pumps and here are the results.
Both tests were done at 13.5 volts:
DCSS"405" (#9000262): 433 lph @ 40 psi, 365 lph @ 60 psi
DCSS"465" (#9000267): 435 lph @ 40 psi, 380 lph @ 60 psi
So, two conclusions... the 400lph pump actually flows a bit better than advertised and the 465 version flows quite a bit less than advertised comparetively.
At a retail price of $160 for the pump and $25 for the filter/install kit for the 405 version and $225 for the pump and $25 for the filter/install kit for the 465 version, in Justin's opinion the cost is not quite worth the gain and I personaly agree. Aproximately 35% increase in price for 5% more flow.
Also, dimensions wise the 465 version of the pump is 11mm taller than the 405 version other than that they are the same as far as reliabilty and components go for use in e85. This 465 e85 version is merely a taller and slightly higher flowing version with the one benefit of running a tad cooler than the 405 when pushed hard with e85. Here are the expected pump lifes from walbro:
DCSS405: 10,000 hours in gasoline, 8,500 hours in E85
DCSS"430": 10,000 hours in both fuel types
Thier goal was a pump to match the 405's performance in gasoline, when used in e85.
