slammed with 10+ wide on front, post your pics!
Jucostud
booooost'd
North of Dallas
I'm doing a square 20x10 setup and wanted to get one thread for everyone to post their pics in. No rim diameter discrimination in this thread...
I'm ordering these tomorrow...
doing the deep concave 20x10's on all 4.
mykvr6
Houston
interested in seeing more as wel, I've been going through the 10" square post over and over in anticipation on getting wheels for the Bullitt. I like a wide rear wheel, but the fronts on most "safe" staggered setups look small to me. Definitely want 10 square at the very least.
2010Mustang
Southern Maryland Mustang
Maryland
18 x 10's
I likey this slammed look! Roll the fenders? I have a 2010 and they told at the shop to fit a 315 under the rear I would need to roll the fenders (which was true) it fit but was very snug, slight bump and fender rub (**i'm lowered on Eibach**) Would rolling the fenders look bad? Thats the only reason I didn't because the tech said it would look stupid if I did..
Jeremy@AirLift
Lansing,MI
^^^ We were able to get away without rolling the fenders, with the 20's and the car lowered all the way the tire does hit the fender slightly.
19COBRA93
Ford Racing
Clinton, Ut
20x10's. Not exactly slammed, but it's low. 285/35 front, and 305/35 rear.
mfergel
Richmond, VA
I don't know how some of you guys don't rub tires against the wheel well. I've got the 19x9.5 SVE drifts and 235/35-19's. With the panhard bar adjusted I have 1/4" at the widest part of the tire extending out past the wheel well. I think I'm just barely getting away with not hitting the wheel well or just haven't hit a bump big enough to fully compress. Thinking I'll probably switch to a 275/40-19 on the back when I'm due for new tires. Wish the SVE Drifts didn't stick out quite so far but I imagine they were partially designed that way to clear Brembo's.
Based on the pics, I think mine stick out about the same as 19cobra93's.
Jucostud
booooost'd
North of Dallas
Can anyone tell me why this thread got moved when the other 3 wheel pic threads are still in the other section?
DWalker
Clinton/Oneida, TN
Be sure and post up some pics when you get these wheels on, I've been going back and forth between those and black 19" drifts...
