why are the gains with hot rod cams so inconsistent?
notastockdohc
Think these cars are stock 300hp stock at the fly, if you make over 300hp at the wheel, then you are making good power at flywheel? I am installing frpp hotrods tomorrow I hope to god I gain something, I don't see how you can't gain anything, the intake and exhaust valves are staying open longer and the are opening more? Even with no tune I don't see how you cant pick up 5 hp?? I figure with a good tuner such as bbr, you should pick up decent hp. I am only running a Mac axle back jlt2 cai, the frpp hot rods, and the 93 oct custom tune, I hope I pick up something. I would hope if I put it on a dyno it would be in the 310-320rwhp area??
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
I picked up 30 hp/3 tq with the HR cams and Kooks LT's with a catted H pipe; this was also on an automatic with 410 gears.
I assume your question was for NA cars because as mentioned before the HR cams are not optimal for FI.
808muscle
Maui
I picked up 3 mph at the track but lost torque with my detroit rockers. Cams need longtubes to reach their potential IMO.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
I picked up a smile that is permanent. Even a plastic surgeon can't remove it from my face.
JEWC_Motorsports
S197 Junkie
Im expecting over 360 @ the wheels after my hotrod/header/frpp intake install.
Greg Hazlett
Official Vendor
Chesapeake, VA
I hope you are not setting yourself up for a disappointment; Luke (LAllison20) had the BBR stg 1 cams, BBK LT's and the FRPP intake and picked up 5 hp....on the dyno with a dyno tune.
JEWC_Motorsports
S197 Junkie
If i only pick up 5 hp ill set the car on fire. lol. I seriously doubt that will happen.
Greg Hazlett
Official Vendor
Chesapeake, VA
Well....not being an ass, just passing on what I saw.....
Do you already have CMDP's? Luke did, that may contributed to the low gains.
What gears do you have and are you an auto/manual? He had 410's which also lead to lower dyno numbers.
JEWC_Motorsports
S197 Junkie
4.10's and i do have cmdp's. I made 306/313 on a mustang dyno with 4.10's, cmdps, jlt 110mm cai, udp, or-h, and a 87 octane torq tune. Who knows?
Lupo222
Fort Lauderdale, FL
I made 341whp with UD pulleys, Hot Rods, LT headers, and a Bama Tune. Would have liked to see #'s with a BBR tune before I got the supercharger though...
Greg Hazlett
Official Vendor
Chesapeake, VA
If you are going with that theory shouldn't be same day, same mods and same tuner?
notastockdohc
Yes eliminate variables. Same car, same dyno same tuner. Put hot rods in, run the numbers, then mother thumpers, then Detroit rockers. See what happens.
Greg Hazlett
Official Vendor
Chesapeake, VA
Wow...while in theory that makes sense and I agree but that would cost a lot of money for 3 cam swaps, 3 tunes and 3 dyno sessions....maybe one day MM&FF or 5.0 will do a cam shootout.
notastockdohc
True, if someone would fund it, they could use my car as the mule lol. I do think these s197 computer/ecu are very complicated and only a good tuner can truely unlock it's secrets.
Greg Hazlett
Official Vendor
Chesapeake, VA
LOL..if you think these are tough wait until you get a 5.0 with all the variable cam timing!
notastockdohc
True, just want to see a 3v cam shoot out. The 5.0 has alot of deserved hype, but these little 4.6 3v are still good.I like my 3v just fine.
Lupo222
Fort Lauderdale, FL
if anyone wants to do this (MM&FF, 5.0), I'll be deployed soon and you can use my car :) You can see how it works with teh supercharger too :)
Greg Hazlett
Official Vendor
Chesapeake, VA
None of those 3 would do well with a s/c.....and I would think if they were to do a shootout a NA car would be what they would want.
