The link didn't work for me Fuel
I editted the above post.
I did, I mean the WG itself. The 2 pipes that hold it together.
That would be an exhaust leak only as those are exhaust pipes. Any vacuum leak would have to be post TB.
I thought I told you about hooking the line to the wg off the compressor housing Mikey? If you did that, then that can't be a vacuum leak.
^^ That sounds perfectly fine to me. I was texting with Mikeyfitz when he was installing his kit, that is what I was referrring to.
FWIW, I had an exhaust leak on my car at the exhaust manifold running 8lbs and still made full boost by 3000-3100 rpm. If this is an exhaust leak it would be enough to hear easily I think.
