World's Quickest Coyote on 275's!!! 9.03@154
Blackblurr2007
jim, can you post a few of your timeslips of anything faster then 8.90s??
If I could of I would. No scanner over hear anymore. I have a kid that like to ruin certain things. I can show you 20 or more in the 8's and 5 or more better than 8.70's when you out this way again. And 2 better than a 60. I have all the videos and will have Gage make a master copy of all the passes with dates/times.
psfracer
billy badass
Valencia, CA
I never scan mine, I just take pictures of them.
psfracer
billy badass
Valencia, CA
jpc triple pump with 3 walbro 450's
it's a great setup,
Good luck on the mid 8s next season. I have no doubt you will get there. Really impressive you are doing this at 3900lbs. I can't believe the trans is surviving.
I would shallow stage just once to run the number. My experience has shown me that deep staging vs shallow staging is worth .1 right there--which would mean a 8.93 with no other changes.
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
i always attempt to shallow stage as much as possible when running for e.t.
Unreal
Gilbert, AZ
Will a Ysi make 1200rwhp through an auto? I know most LSX people max them out in the upper 1000s. I'm making low 900s on 11psi but didn't think a Ysi would make 1200.
beefcake
Official Vendor
Bethel, Ohio
I'm hoping....
Bud
Northern Colorado
The blower can only push so much air, hopefully good compression and a more efficient motor makes more power with that same amount of air than an LSX though. These motors seem to do extremely well for the amount of air thrown at them.
djniknala
Beef what's your fuel setup? Triple 405's and ID2000's? What do the popular tuners like to run for base pressure on return setups for the copperhead ecu?
NitroPsycho
it's a great setup,
I don't know as far as the fuel pressure but he said that earlier in the thread....
Beef, you said you deep stage for RT's right? Do they run a pro tree where you race or a full tree?
Nitro
beefcake
Official Vendor
Bethel, Ohio
Nitro
shallow stage for e.t., deep stage for brackets for better r/t's
