Looking forward to the test results.
So am I.
It just keeps looking better. Have you given any thought to just milling a minimum amount so there is room left? You have put a lot of work into these and it would be a shame if the lifespan was shortened when it didn't have to be. IMO of course, lol.
Looks good, in for flow numbers! Any chance you can test for port velocity as well??
I was using a propane torch like in the video above, the other end of the head was to hot to touch since I had it there so long. I am going to have a buddy weld it up. I am ready to get the heads on the bench.I'm assuming you need to heat up the surrounding metal so it bonds, similar to welding but lower temps? Maybe hitting the intake manifold with a propane torch to warm it up may help.
Thanks! If un shrouding the valves helps, then these should make some REALLY nice gains. How ever they do, I will take it for my first port job.They look great!
I guess you could, but the area I am working on is the head side.What was your shipping address again? Lol
Looks great, expected nothing less from you...
Also, can't you just weld those plates to your intake?
