05stroker
Never enough power guy!
pretty much, used the fel pro gasket, spent a ton of time in the bowl areas and the short turn radius. The factory exh ports are Very restrictive....much more so than the intake IMO
Agreed, I did mine freehand and they came to the same cc as the FRPP/Livernois High Flow heads. Once you start cutting it is obvious where you need to cut on the exhaust side.
