Backup Camera Install
Have had the Pioneer AVIC-8000NEX GPS Receiver installed since September 2014 but just this spring I picked up a Pioneer ND-BC6 Backup Camera.
This is a stick on camera and I am positioning it to the passenger side of the license plate light.
Started the install this afternoon by proceeding as follows (no pictures of the install process as all four batteries for my point and shoot camera were dead):
1. Removed the two screws with a Philips screwdriver and dropped the license plate light housing.
2. Disconnected the license plate light harness.
3. Opened the trunk and removed the back panel push pins and removed the back panel.
4. Using an 11mm deep socket and ¼” ratchet removed the three nuts retaining the passenger side tail light.
5. Carefully removed the tail light.
6. Fished a small diameter piece of bamboo (only thing I had as I could not find a wire coat hanger) from the license plate light hole to the bumper opening below the tail light.
7. Positioned the camera, marked the position for the backup camera wire to pass through the bumper with an awl.
8. Drilled a pilot hole and then a 7/16” hole which was large enough for the backup camera connector end to pass through.
9. Passed the backup camera connector through the hole and out the license plate light hole.
10. Taped the backup camera wire connector to the end of the bamboo and pulled the connector and wire up through to the passenger tail light.
11. Made a slit in a rubber grommet and pulled the connector and wire through into the trunk.
12. Cleaned the mounting position with some alcohol and stuck the camera on.
13. Sliced a grommet inserted the camera wire and pushed the grommet into the whole with a small screwdriver.
14. Connected the light harness back into the light housing and remounted the license plate housing with the two Philips screws.
15. Re-Installed the passenger side tail light.
A Camera battery was finally charged enough for a picture.
Next up is routing the backup camera wire harness through the trunk, under the rear seat delete panel, into the center console and finally to the radio.
