Shotokan1509
IF you possibly could get pictures underneath yours, I would be in debt to ya!
Not great pics, hard on just jack stands. I used variety of hardware I had laying around, I'm sure with your access to parts bins you can make it all look factory. The most important piece in my opinion is the very center (2nd pic on the right). I used hole saw to make opening behind a bolt hole I drilled. I snuck a nut inside and held with finger to tighten bolt from bottom. I never bothered cleaning up the hole as this is all impossible to see on the ground, again I'm sure you can find some kind of plug to make it look factory
