Decided to try the 15+ seat position sensor on the Recaro seats who knows it may work. If it does fantastic as it is easier than trying to install the 08 style sensor onto the 15+ rail. Basically cut the connectors off of both harnesses and installed the 15+ connector in place of the 08 connector on the 08 harness.
15+ position sensor connector top and 08 bottom.
15+ Connector no 15+ wiring diagrams yet, so guessing:
YE-RE – sensor feed
BK – ground
08 Connector reading the wiring diagram:
LG - wire is the “Driver Seat Track Sensor Feed”
BK-LB – wire goes to ground
Joined the BK and BK-LB wires and the YE-RE and LG wires.
08 Connector soldered onto the 15+ harness.
Covering and tape applied.
Seat position sensor connector installed and harness secured with cable ties.
08 seat belt receptacle harness connected and secured.
Driver seat wiring completed (except side air bag) and seat ready to install after a little black paint is applied to the rails.
Two front rails bolts were removed with a 13mm socket and the two rear bolts with a 15mm socket. Seat and air bag harnesses were unplugged from the body harness and two men and a boy lifted the seat out. A little vacuum and it is already for the new seat.
Modified Air Bag Terminator installed.
