BullittSS
Probably overlooking an option, but is there a way to display the most recent replies first?
Pics are not small here. The fit your screen size. Post a link to where they are small?
Every pic on the pic whore thread is the normal size. Look at this part of the thread.
https://www.s197forum.com/threads/the-pic-whore-club-knock-before-you-enter.58711/page-724
This new format sucks! Not user friendly at all and down right unappealing.
Attached images look tiny and have all kinds of garbage written next to them.
Attached images should be big and maybe just show the thumbnails at the bottom of the post.
And quoted images show up as thumbnails too, which I can kinda understand, when 14 people in a row all quote the same fucking pic(s) over and over again.
At least all the posts are in order again. It was annoying reading through a thread and seeing all these newer posts thrown in with old posts.
I personally dont mind the new skin.
Youre probably right. It was like all of a sudden the posts were out of order and if a member quoted a post the new post would be directly under the post that was quoted regardless if it was the last post or not. This thread is acting normal again so I think its safe to say its fixed.He(the guy that is doing the conversion for me) was probably still tweaking the site when you saw it out of wack.
At least Tapatalk is still working.
What did you try to post in the censored text?
it's not just you, I think it must be a data base issue that got messed up in the migration to the new software. If I get a better answer from the guy who did the work I'll update everyone.Why does it take me back to date in October when I click "go to first unread".
And I have been here recently ??????
here's the added detail:
After initial conversion, the forum has no idea which threads anyone actually read back on vBulletin. (Read thread and forum markers are not part of an import process.) So, it can mis-position you. If that's an issue, you can mark all forum read and then going forward, you should always be positioned at the new replies in threads.
The reason for October is the database only stores a month of read-markers. So, everyone started out with all threads since a month ago being unread.
If people don't use Mark Forums Read, it'll eventually work out as they read things, or as time goes by.
