AFCO Dual Pass Heat Exchanger w/Dual 10" Spal Fans
stanglifemike
aka boostedbanana
Douglasville, GA
NICE!! Are all of the Afco's without fans the smaller one? I have a Afco on mine but it looks bigger than the one you posted without fans, maybe its my imagination, maybe I should measure it. Would you guys be willing to do trade-ins of the fanless Afco units? Also, will these fit on a GT? I believe mine is touching, or almost touching the black shield on the bottom side of the car?
Jared@Lethal
Official Vendor
Mike,
There's only 2 AFCO heat exchangers available. The pro series 80280NDP and the 80280PRO. The regular pro series without fans is indeed the smaller of the 2.
I've been told by AFCO that the unit with fans will bolt right up just like their pro-series one does. However we still haven't verified if there are clearance issues. Regardless of which one you go with you'll have to re-route some hoses. I mention it because the hose routing on the GT is different then the GT500.
Lastly,
Unfortunately we don't offer trade-ins.
Hope that helps.
Jared
stanglifemike
aka boostedbanana
Douglasville, GA
Thanks, yea I was halfway kidding about the trade-in comment, wishful thinking I suppose. As far as re-routing hoses, the inlet and outlet looks to be the same locations as my current Afco....or maybe that wasn't directed towards me, just a general statement. Once I see if this will work with a stock GT bumper, I think I'll purchase it along with a spare-tire location intercooler reservoir. Thanks for the info!!
Jared@Lethal
Official Vendor
Just wanted to let you guys know that a customer of mine with a Saleen installed the AFCO heat exchanger with fans on his car and reported back to me letting me know it was a direct fit with no modification necessary.
fiverivers
How are are fan triggered, the gt 500 its just plug and play but its on the same way on the gt. I have roush p-51 and would like to know how would the fans be triggered.
thanks
Jared@Lethal
Official Vendor
thanks
The fans come on at the same time the intercooler pump turns on. So on your car now whatever temperature the IC pump is set at whenever it triggers the pump the fans would trigger as well.
Please let me know if you have any other questions.
Thanks, Jared
fiverivers
Thanks, Jared
that is only true for gt500, the roush p-51 is a gt with forged bottom end and tvs 2300, the IC pump come on when the key is on. since the stock doesn't come supercharged there is no code in the pcm for IC pump control. And I would think having two big fans running all the time wouldn't be that good for the battery.
Jared@Lethal
Official Vendor
Then you could wire it to a switch so that it would be hot when keyed on but it only run when the switch is turned on.
Jared
