WTB: Saleen 3.8 or 3.6 pulley
RedMosesSC
NYC
Sup All,
I have a 435hp model 2006 Saleen S281 SC, i have an 475hp CAI and im looking for a smaller pulley to go along with it, preffereably a stock Saleen pulley that one of you guys with a 475hp model swapped out to upgrade.
*JZ*
Boynton Beach, Florida
We make our own pulleys.
They are $75 shipped
http://www.blowbyracing.com/bbrsa3scpu.html
yhst-14752229404082_2099_107470833
06Stang
Saleen Supercharged
ABQ, NM
I always wondered why they dont offer a swap out service for pulleys when you upgrade. Give some money back for the used pulley depending on condition.
Agent Jones
San Antonio, Texas
Sup All,
i would recommend going to a 3.6. I will have one available in about a week or so. Im going down to a 3.4. Also take a look at BBR and Brenspeed if you want a new one. i would highly recommend John @ BBR.
RedMosesSC
NYC
The 07+ models run the 3.8 if im not mistaken, i dont want to stress out my fuel system until i get a Dynotune, were you running the 3.6 on the stock pump?
I coudl wait a week, PM with a price shipped to 11375, thanks!
Agent Jones
San Antonio, Texas
Right now im on the 3.6 pulley, stock pump, 8psi, 440rwhp, tuned by jon lund. They did datalogging the pump and its fine. i cant go to the 3.4 with stock pump but the 3.6 is working fine and im well within safe ranges on the duty cycles. Im adding a bap and then going to the 3.4.
RedMosesSC
NYC
Are you upgrading your injectors too? Im looking for 39lb's as well to complete the upgrade.
Also, i presume i need a shorter belt, do you know what size works with the 3.6 off the top of your head?
Agent Jones
San Antonio, Texas
I have 42lb injectors and i think ill be fine with those with the 3.4. im gonna double check with my tuner....here is a list of belt sizes. i might go down a belt size so i might have both pulley and belt for sale.
Gates K061080 Micro-V (13/16" x 108 ¾" – 6 rib) or NAPA 25-061080 (3.8", 3.6" & 3.4"* Pulleys Only). *The K061080 belt can be used with the 3.4" S/C pulley if used in combination with the V10 W/P pulley and 90mm OEM idler pulley in place of the 76mm Saleen idler pulley.
Gates K061075 Micro-V (13/16" x 108 1/8" – 6 rib) or NAPA 25-061075 (3.4", 3.2"* & 3.0"* Pulleys Only) *When using 3.2" & 3.0" S/C pulleys, change W/P Pulley to F7UZ-8509-AA (5.515" diameter – 17.317" circumference) for a V10 truck application - improves S/C pulley belt wrap.
Gates K061073 Micro-V (13/16" x 107 7/8" – 6 rib) or NAPA 25-061073 (2.87" S/C Pulley) When using 2.87" S/C pulley, change W/P Pulley to F7UZ-8509-AA (5.515" diameter – 17.317" circumference) for a V10 truck application - improves S/C pulley belt wrap.
Stock "GT" W/P pulley (F6TZ-8509-AA) is 5.082" diameter – 15.957" circumference.
RedMosesSC
NYC
Agent J, still interested, so lemme know once you find out whats, what.
